Author Topic: Washer ID ?  (Read 738 times)
Offline lash
Washer ID ?
« on: February 15, 2024, 07:09:29 AM »
After stripping down the engine and putting parts in various bins I found this laying under the cases. Any idea where it goes? Not the starter gear spacer for sure!
  • I'm back
Re: Washer ID ?
« Reply #1 on: February 15, 2024, 07:20:13 AM »
Can you at least try to remember in what bike you've found it?
Offline lash
Re: Washer ID ?
« Reply #2 on: February 15, 2024, 07:23:50 AM »
1974 cb750k
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Washer ID ?
« Reply #3 on: February 15, 2024, 07:26:37 AM »
How thick is it? Maybe oil filter washer (between spring and filter) or a washer from the clutch assembly?
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline lash
Re: Washer ID ?
« Reply #4 on: February 15, 2024, 07:40:57 AM »
Not oil filter or clutch..
Re: Washer ID ?
« Reply #5 on: February 15, 2024, 08:07:47 AM »
Valve spring seat shim?
TAMTF...
Wilbur
Projects:
Re: Washer ID ?
« Reply #6 on: February 15, 2024, 08:13:32 AM »
Put it in a zip lock bag and put a ??????? On it.
Offline lash
Re: Washer ID ?
« Reply #7 on: February 15, 2024, 08:21:11 AM »
I will check it later but I think it might be is one of the thrust washers from the top shaft of the transmission
Offline lash
Re: Washer ID ?
« Reply #8 on: February 16, 2024, 09:22:27 AM »
It is a thrust washer between the case bearing and the first gear.. Now I feel better. Can’t put the engine together until I knew I had no spare pieces!
Re: Washer ID ?
« Reply #9 on: February 16, 2024, 10:22:45 AM »
I have had worries about the washer behind the primary hub.
Did I really had it on the shaft?
It can easy fall off... ;)
