Author Topic: 1975 400/4 Clutch  (Read 385 times)
Offline MDW
  • 1975 Honda 400 Four Super Sport
1975 400/4 Clutch
« on: February 17, 2024, 10:47:53 AM »
I am inspecting the clutch on my 400/4. When I last rode it before starting restoration the clutch slipped, or appeared to. I checked the friction plates and they are all in spec. 2 of the clutch plates are out of spec from a flatness perspective. I went online to order new plates and saw in the diagram attached that there is something called a "set ring special" (number 22). Mine doesn't have this. Does anyone know what that part is and if it is a option or a requirement? I also don't seem to have the parts 17 and 18 (disc spring seat and clutch disc spring).
Thanks.
« Last Edit: February 17, 2024, 10:59:52 AM by MDW »
Offline newday777
Re: 1975 400/4 Clutch
« Reply #1 on: February 17, 2024, 12:16:20 PM »
That sounds alot like the wrong oil was put in the motor. Car oils with friction modifiers cause the clutch to slip.
Stu
My current rides
Prior bikes....
« Reply #2 on: February 17, 2024, 06:59:37 PM »
If this isn't caused by Newday777's observation:
Parts 22, 11 and 4 in the diagram are parts for the spring pack that lightly seats all the plates to prevent them from sticking or 'chattering' when the oil is cold, too thin, or very old (as in, parked too long, so plates stuck together). They are part of the overall height of the clutch pack. If they are missing, they are hard to come by: you might then consider installing and extra steel plate in their place (or maybe 2 of them) or else an extra fiber plate and steel plate, to take up the space. Otherwise the clutch springs will not have enough force to close the clutch pack when the lever is released, and it will slip.
Offline newday777
« Reply #3 on: February 18, 2024, 03:11:24 AM »
Thanks.
What oil specifically was put in the bike?
Stu
My current rides
Prior bikes....
Offline Kevin
« Reply #4 on: February 18, 2024, 06:46:26 AM »
Your description of parts 17 and 18 don't match what is pictured.
I'm wondering if you have a clutch pack out of a CB350F. Take a look at the 350F parts manual (there is one on this forum) to see if that matches what you have.
Sent from my SM-S908U1 using Tapatalk
A couple of 400F's and a
'98 Suzuki Intruder VS1400 ~ for long rides
« Reply #5 on: February 18, 2024, 07:06:44 AM »
17 and 18 are a washer and a nut, please check and specify what you meant
