Author Topic: Where do you buy your points from?  (Read 13228 times)
Offline Dos
  • Owner of a cb350f
« on: March 03, 2024, 04:24:04 AM »
Hey y’all,
I was riding and all of a sudden lost ignition on 2.3.
My points completely broke in half!
I remember buying some in the past that were rubbish.
A forum member instructed me that points for the CB350F’s should be bought on a specific site.
I can’t find that post though unfortunately :/
Do you have any recommendations? I will probably buy an Allen screw set as well as mine are very stripped.
Thank you!
Re: Where do you buy your points from?
« Reply #1 on: March 03, 2024, 07:42:42 AM »
All the sohc fours use the same points plate assembly, go to David Silver spares and look there it will cost a bit but you get the complete plate with points and condensers plus the wireing
Search part number 30200-300-154
« Last Edit: March 03, 2024, 07:49:26 AM by bryanj »
« Reply #2 on: March 03, 2024, 08:40:06 AM »
Aftermarket points and condensers are junk.
Get them from Honda.
South Sound Honda in Washington has the best on line pricing.
https://www.southsoundhonda.com/--xpartsstream
Offline Dos
  • Owner of a cb350f
« Reply #3 on: March 03, 2024, 12:01:33 PM »
Thank you!
Offline Dos
  • Owner of a cb350f
« Reply #4 on: March 03, 2024, 12:29:09 PM »
I was going to order these I don't see how they could be worse?
Offline Dos
  • Owner of a cb350f
« Reply #6 on: March 03, 2024, 07:57:41 PM »
https://4into1.com/points-set-left-right-honda-cb350f-cb400f/
I'm not certain the advertising on those points that 4into1 has are 'on the mark'.
The best points will be in red OEM Honda packages(from a Honda dealer)showing Honda part numbers,imo.
« Reply #7 on: March 03, 2024, 09:00:56 PM »
2 things here...
1.  For years, literally anyone selling non-oem points and condensors no matter what they say in the ad or on the phone, when they turn up, they will be Daiichi brand...straight useless garbage.
2.  I have not bought much from 4 into 1, but what I have was also straight worthless garbage...just not doing it anymore.
You want your bike to run?...you gotta drop the lettuce on the oem stuff or go electronic.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #9 on: March 03, 2024, 09:23:24 PM »
what about the TEC brand? I remember seeing something about them on the forum mind you it was years ago.
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
« Reply #10 on: March 03, 2024, 09:43:30 PM »
TEC points ARE Honda oem...Honda also uses/ed Denso and Hitachi
These firms do not sell points and condensors independently.  They are only available through Honda.
« Last Edit: March 03, 2024, 09:46:19 PM by seanbarney41 »
Offline Cl550
« Reply #11 on: March 04, 2024, 05:54:44 AM »
Try common-motor.com. Just got some and they appear well made. They specialize in these bikes, work on them and have great videos.
« Reply #12 on: March 04, 2024, 06:27:57 AM »
Bet you they are Daiichi and if they work at all, not more than 500 miles
« Reply #13 on: March 04, 2024, 06:36:13 AM »
Yamiya is another good source of parts
« Reply #14 on: March 04, 2024, 07:21:53 AM »
These appear to be Toyo...
https://www.southsoundhonda.com/--xpartsstream#/s/HOM//30200-300-154//1/y
« Reply #15 on: March 04, 2024, 09:21:09 AM »
Your old condensors are likely fine, stay with those. Just get new points.
« Reply #16 on: March 04, 2024, 10:03:25 AM »
TEC point plate and point 2:3 have a guide groove/pin to keep it correct when adjusting it.
That has been up in a thread on this forum achear or 2 ago.
Think it was forum member  Deltarider that posted some photos
Daichii not. That can explain the long time adjusting and not get it right.
TEC points have a blue/purple color dot.
Plate must be TEC too.
« Reply #17 on: March 05, 2024, 04:59:48 AM »
I have dealt with TEC points mostly and they are very good quality; they live for ever. I can't remember I have renewed them more than just once in over 140.000km, be it that for the last 60.000km they only had to switch the control current for my homebuilt EI, which in amps is far much less than in the original configuration > no pitting.
« Reply #18 on: March 05, 2024, 06:49:54 AM »
Your old condensers are likely fine...
If they are not aftermarket...
Offline Dos
  • Owner of a cb350f
« Reply #19 on: March 05, 2024, 10:59:31 AM »
Thank you!
I ordered them and got a message back from the seller saying they were discontinued! :(
Where should I order the proper points?
Offline Dos
  • Owner of a cb350f
« Reply #20 on: March 05, 2024, 11:00:54 AM »
I went on their site.. I didn't see any for the cb350f.. did you see them there? I am wondering if the cb500 points they have are compatible.
« Reply #21 on: March 05, 2024, 11:18:32 AM »
Like i said before all the complete assemblies are the same so the parts on them are as well
« Reply #22 on: March 05, 2024, 11:40:04 AM »
A CB750 complete points plate will also work on a CB350F ?
« Reply #23 on: March 05, 2024, 12:05:13 PM »
And a 400 and 500 and 550
Offline Dos
  • Owner of a cb350f
« Reply #24 on: March 05, 2024, 01:04:53 PM »
Ah okay so just confirming
These WILL work on a cb350f?
https://www.common-motor.com/honda-cb550-cb550k-cb550f-point-set
