The SOHC/4 World Tour is in under way.
Someone know where to buy these beside webike?Bert
Quote from: bert96 on March 03, 2024, 08:41:06 AMSomeone know where to buy these beside webike?BertI'm surprised anyone is making those at all.Are your jewels missing or just faded?The ones on my panel were faded.I replaced the bulbs in my panel with colored LED's.The colors are nice and bright now when the bulbs are lit.
Quote from: CycleRanger on March 03, 2024, 09:43:32 AMQuote from: bert96 on March 03, 2024, 08:41:06 AMSomeone know where to buy these beside webike?BertI'm surprised anyone is making those at all.Are your jewels missing or just faded?The ones on my panel were faded.I replaced the bulbs in my panel with colored LED's.The colors are nice and bright now when the bulbs are lit.I'm rebuilding my bike in like new condition. So, i don't cut corners... Bert
Recall the trick for restoring plastics after polishing out any light scratches you clean them coat them with Future Acryllic Floor finish with . and they should dry with high gloss.When it needs refreshed you can clean it well with high purity alcohol and breaks out an airbrush again to give them another coat…David
Quote from: RAFster122s on March 05, 2024, 04:42:34 PMRecall the trick for restoring plastics after polishing out any light scratches you clean them coat them with Future Acryllic Floor finish with . and they should dry with high gloss.When it needs refreshed you can clean it well with high purity alcohol and breaks out an airbrush again to give them another coat…DavidAlternatively, shoot a coat of urethane clear and you have a more permanent solution that is much better and more UV stable…SprayMax gloss urethane Look on repaintsupply.com it has a shelf life and must use can completely within 24 hours a of activation, ideally fart less than 24 hours!!Gather up several things and them all prepped and apply 2 coats. YOU MUST WEAR PROTECTIVE GEAR Painting w/Urethane, not doing so can have Lethal or Crippling Results!!!!!!!Sounds like that product, and it's Pledge replacement are both long gone ??
