Author Topic: Where do I Start - M-Unit  (Read 23225 times)
Offline chesterburnet111
« on: September 02, 2024, 08:41:10 AM »
I'm going to be getting my CB550 frame over to the powder coater sometime this month. I've been mocking it up and have almost all of the issues covered and the bike is over at my welder's shop. which is getting me to the point that I dread and and am also excited about. Wiring up my M-Unit.
I figured it's time to dig in and figure this thing out. So this is where I'm at. My motor is built and has an electronic ignition installed. I have bought to date.....M-Unit Blue, Motoscope Pro, Breakout box, a 2 & 3 button mo.switches, no.blaze pins, 2 TST led rear turn signals, speedometer sensor, air temp sensor, mo.lock, led headlight, built in switches on clutch and front brake, rear brake switch, Rick's rectifier, wiring kit, Antigravity battery, new Dynatek coils and a new solenoid.
I want to start working on my wiring diagrams and am hoping there might be some good examples kicking around that I can use as examples. My skill level is that I can wire up a house from the box out, built speaker crossovers. I've done turn signal shutoff module and changed out relays and a lot of other minor electrical work on my late model Yamahas and part of my job is electronic access control. I think I have some skills to build on.
I was also hoping to get some recommendations for videos and how toos aside for the Motogadget documentaion. I like to educate myself when I do these kind of projects as the learning and doing part is one of the fun things to accomplish.
I'm not totally useless, I can still serve as a bad example
Re: Where do I Start - M-Unit
« Reply #1 on: September 28, 2024, 04:25:13 PM »
yes
« Reply #2 on: November 26, 2024, 07:36:52 AM »
I forget where I saw this - I have an electronic ignition from Charlie's Place and somebody posted that it does not work with M-Unit. Can anyone confirm this?
Offline Finnigan
« Reply #3 on: November 26, 2024, 02:29:06 PM »
m-unit and charlies place ignition worked fine on my 450 build
« Reply #4 on: November 26, 2024, 06:50:43 PM »
That's what I would have thought. Sometimes it's difficult to parse through the bull#$%* on motorcycle forums.
Offline Acidbass32
« Reply #5 on: August 11, 2025, 09:42:26 AM »
Did you end up getting the information you needed? I know classic Octane on Youtube has a great step by step on wiring up a MUnit Blue on a cb550. I am just about to start this project myself on mine but dreading it because I don't really have any of the factory harness to go off of.
