Author Topic: rounded screw in carb slide.  (Read 668 times)
Offline katman
« on: March 26, 2024, 06:08:13 AM »
Is there anyway to get the small screw out of the carb slide on the early style carbs for Cb750. Starting to round out.
Online willbird
Re: rounded screw in carb slide.
« Reply #1 on: March 26, 2024, 07:44:00 AM »
Down inside that holds the needle down ? I tore apart a set of carbs and found a red loctite on that screw. But I gave it a bath in the hot ultrasonic then tapped a good JIS screwdriver into the screw with a hammer, then it came out. Benelli said he has boiled a few to loosen up that screw.
Vessel makes a normal looking screwdriver that is an impact screwdriver, I have not bought any yet.
https://www.vesseltools.com/handtools/screwdrivers/megadora/980-series-detail
Would need to make sure it is JIS.
« Last Edit: March 26, 2024, 07:47:27 AM by willbird »
« Reply #2 on: March 26, 2024, 07:53:51 AM »
Yes, be sure to use a JIS screwdriver. A Phillips will ruin it.
Offline katman
« Reply #3 on: March 26, 2024, 09:15:41 AM »
Yea, used set I bought. Someone has been in them before. Was using my JIS. I didn't try tapping on it though.
Online willbird
« Reply #4 on: March 26, 2024, 12:29:55 PM »
If they used loctite you might be able to see it from the bottom side. I know somebody had been inside the set I got from Ebay because the mainjets were Nylon or some other white plastic LOL.
Offline Flyin900
« Reply #5 on: March 27, 2024, 05:04:58 AM »
Use some heat on the bottom of the threaded part in the slide and a proper JIS screwdriver that you tap into the damaged threads and it should release. Even if there is no Loctite the varnished gas on the threads lock it into the slide body.
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
