Author Topic: Maybe time to re-look at: LED lights?  (Read 5600 times)
Re: Maybe time to re-look at: LED lights?
« Reply #25 on: March 29, 2024, 09:24:01 AM »
I bet that cooling assembly is a snug fit.
Hopefully no need to modify the bucket ;D
I had to check!
Stopped the ongoing movie, told wife I have to check something in the garage 5 minutes. Not first time.
I do not like to think about fit or not when I can verify it direct.
I made the bulb taller, 13mm more inside bucket.
It fits.
Need to fix wires inside bucket with tape.
It looks like a refugee camp for wires and thicker connectors!! ;D
I closed it and fastened with the 3 M5 screws.
All functions are functional too.
That LED H4 fan has worked fine since 2015.
I had another one in my K2 where the fan started to scream after a season.
This yellow/white spec 3800 and 4000lm  eBay vs Amazon descriptons.
« Last Edit: March 29, 2024, 10:41:20 AM by PeWe »
« Reply #26 on: March 29, 2024, 09:52:19 AM »
Is that a fan type Per?
« Reply #27 on: March 29, 2024, 12:06:05 PM »
Yes, an old one.
The new ones have also fan.
I'll update when I have got them. (2-3 weeks)
  • I'm back
« Reply #28 on: March 29, 2024, 01:58:19 PM »
Be careful about what LEDs you buy. LEDs are output rated in Lumens as well as watts. If a site doesn't show lumens rating,  stay away. The higher the lumens rating the better light you will get.
I am afraid I disagree. Lumens means little: it's light spread in any direction. It's Lux what matters. I don't make decisions on what sites and advertisements say anyway. Some brands have good reputations and offer good products. Other less known brands offer stuff that only performs well in their ads...
Offline Korven
« Reply #29 on: March 29, 2024, 04:00:04 PM »
1 Lux is 1 lumen/m2 (at a distance of 1 meter). So saying that lumens means little isnt true, normally lux is measured in the most light intensive area and lumens in a integrating sphere (360). But i can with good confidence say that the reflector most likely has very little loss and will help reflect all that stray light. All Comerical lights within the EU should have a lumen value declared on their packaging (and if its in a 360, 180, 120 or 90degree sphere). You are making a good point about companies not living up to their claims especially the aliexpress/cheapo stuff. It's easy to put on a few LED's and a few resistors on a chunk of metal and call it a lamp.
Offline fire113
« Reply #30 on: March 29, 2024, 05:00:51 PM »
Osram H4 LED Night Breaker or Phillips Ultron Pro 6000, I used both in my old cars.
But in Germany it is not allowed to use it with a CB750 :/
« Reply #31 on: March 29, 2024, 11:31:30 PM »
LED H4 is good for the total power consumption, especially when using a Dyna-S.
I have relays too, Hi, Lo and ign with thicker wires direct from battery.
My K6 has also for the dual horns and parking off together with Lo.
I switched to std H4 when visiting the vehicle inspection so to they should not complain on the light pattern that is not that sharp with the LED. Most important that meeting cars do not flash their lamps.
No more vehicle inspections for my bikes. 40 years old no need.
My ongoing CB750 build need one when completed. Last inspection was 1993.
It will be interesting how the  new LED H4 will work.
« Last Edit: March 29, 2024, 11:42:09 PM by PeWe »
  • I'm back
« Reply #32 on: March 30, 2024, 03:41:55 AM »
I made my remark on Lux and Lumen because the exact position of the H4 filaments will guarantee the emitted light will be where it is needed. With an aftermarket Led in an OEM reflector its anyone's guess. Bottom line for me is, that - inspite of efforts to upgrade - I want my bike to be streetlegal. Philips and Osram will offer only approved products.
The color temp is also a thing. There have been ralley riders that preferred yellow lights. Best lights I ever had were the then standard yellow quartz iodine bulbs in the trapezium shaped CibiƩ headlamps on my Peugeot 504GL.
« Last Edit: March 30, 2024, 08:23:00 AM by Deltarider »
« Reply #33 on: March 30, 2024, 08:09:48 AM »
I was worried about that when I replaced the lights in my Jeep and Colorado. The bulbs really made a difference and the pattern is spot on. There must be a lot of work put into the positioning of the chip(s) to make that happen.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #34 on: April 01, 2024, 04:24:52 AM »
The Sylvania LED bulbs from the auto part store are working just fine in the touring bike.
Finding a decent set of led headlight bulbs was a different story.  Most of the vendors will promise stadium quality lighting.  But the sad truth is their product will get outshined by a bic lighter.
« Reply #35 on: April 10, 2024, 08:30:37 PM »
I got the ordered yellow/white H4 LED yesterday.
Tested it direct after work.
A road test will be interesting.
Yellow Lo
White Hi
Auxilary LEDs too.
New  taller H4 vs old H4 LED.
New has LEDs on both sides, old only 1.
« Last Edit: April 10, 2024, 08:32:44 PM by PeWe »
« Reply #36 on: April 11, 2024, 07:18:01 PM »
That's wild! Yellow LOW beam and White HI beam?
« Reply #37 on: April 12, 2024, 07:58:17 AM »
Did I miss where you mentioned the brand?
They look very cool.
« Reply #38 on: April 12, 2024, 09:49:47 AM »
eBay order post 20.
Shipped from China.
Quick shipping for China parts.
I hope weather will be good the nearest days for a test ;)
The bike must be seen by others  with that urinated Lo light!!
The days are longer so no darkness until around 9pm. A little bit too late for a ride to test all lights.
In my 18-20's just the beginning of the evening!
« Reply #39 on: April 12, 2024, 09:50:18 AM »
Yes!
Specified to 36W.
« Reply #40 on: April 12, 2024, 08:40:39 PM »
Yes!
Specified to 36W.
That might be a good addition to the CB500/550 and CB350F bikes...
« Reply #41 on: April 13, 2024, 12:22:41 AM »
Yes!
Specified to 36W.
That's why I installed the first LED H4 with spec 30/40W. I think I measured 35W something.
More power for other things.
With the LED rear, less power needed when braking.
« Reply #42 on: April 13, 2024, 04:21:57 AM »
Per great photos on the headlight bulb comparison - what connectors are you using to install the bulb into the headlight bucket/wiring harness? Cant tell from your photos.
Thanks
Andy
« Reply #43 on: April 13, 2024, 05:12:55 AM »
Hi Andy,
Std H4 connector.
My K6 had H4 from the very beginning. (Hi, Lo, Ground).
Like this one wired to handlebar switch and ground inside bucket.
Male connector on bulb.
Std H4 bulb has the connector connected at rear making it taller.
LED bulbs that are taller have its male connector via a cable so the total lenght the bucket has to accept does not differ that much.
« Last Edit: April 13, 2024, 05:31:42 AM by PeWe »
« Reply #44 on: April 13, 2024, 07:48:37 AM »
Looks great, I think I'm going to do it as well as the brake/tail light
« Reply #45 on: April 13, 2024, 10:42:22 AM »
Update after a ride.
The yellow/white H4 LED lamp did not last long. It entered a glowing mode within 30 minutes ! :(
I have another order of same lamp.
I'll see how next will work. I doubt they all are bad.
My earlier H4 LEDs have worked fine.  Also no brand from China.
One got a high squeeling sound after 3 years or so. Light still  OK.
I tested my old lamp direct after the ride to be sure about connections OK.
Old lamp work fine.
Next will arrive in a few days.
Amazon order of 2.
Update:
I got a quick reply from seller after I informed about the faulty part.
A new has been shipped, tracking number in reply.
« Last Edit: April 14, 2024, 10:14:08 PM by PeWe »
Offline flatlander
« Reply #46 on: April 14, 2024, 07:17:02 AM »
hondaman, back to your original question:
i've got the pictured LED bulb in my tail light. throws light in all directions, i.e. the light also shines to the sides. brake light works great and as it's white, also the license plate is properly illuminated.
searching for the part number throws up a few hits on the interweb... i think i got it from superbrightleds?
« Last Edit: April 14, 2024, 07:19:25 AM by flatlander »
« Reply #47 on: April 14, 2024, 08:03:14 AM »
That one looks great!
« Reply #48 on: April 14, 2024, 10:57:49 AM »
You don't get a pink taillight from using white LED?
I learned long ago that you need red LED in a taillight.
Offline flatlander
« Reply #49 on: April 14, 2024, 11:43:44 AM »
doesn't look pink to me.
white light through a red lens will appear red. why would that change only because it's a LED source?
