Author Topic: Exhaust Stud Helicoil pulled out?  (Read 789 times)
Offline LiveeviL81
  • Turbomatic
« on: March 28, 2024, 08:30:23 PM »
Hey Guys!
Bad news to start Easter weekend... When tightening my exhaust studs down, my 4th cylinder upper stud pulled out. I "unscrewed" the helicoil the P/O must've installed but I don't see much threads left to throw another helicoil in. I'm pretty upset as I was only at 8ish ftlbs and had not fully squished the copper down.
Thoughts? Hoping I can salvage it with a new helicoil tomorrow, if not... I guess I'll upsize the stud to M10 and see what happen.
Kaleb
Young, Dumb, and Broke, hoping to fix 2 of those.
Offline CycleRanger
  • No comment about being an
Re: Exhaust Stud Helicoil pulled out?
« Reply #1 on: March 28, 2024, 08:41:46 PM »
You could go up a size and use a step stud.
« Reply #2 on: March 28, 2024, 08:46:54 PM »
 :)  I've seen those in certain hdwe. stores a while back;excellent product.
« Reply #3 on: March 28, 2024, 08:54:53 PM »
Maybe also look at Keenserts: I've used them in both exhaust port situations like yours and in the upper engine cases when the long studs got too corroded in the case and the threads ripped out when the studs were removed, requiring a larger hole to fix it. Keenserts will require a 10mm tapped hole for the 8mm stud size, and come in all the threads needed. They mount flush or non-flush, depending on the ones you choose.
Offline LiveeviL81
  • Turbomatic
« Reply #5 on: March 28, 2024, 09:20:21 PM »
I purchased these reducers https://www.amazon.com/gp/product/B0BZV1DR71/ref=ox_sc_act_title_1?smid=A15ZZE9TVIJLI0&psc=1 incase I do have to tap to M10.  I'll also look for the step studs. Didn't know they existed.
« Reply #6 on: March 28, 2024, 09:32:14 PM »
I just watched an installation tutorial on these and they look good.
Do they come as a complete kit?(6mm,8mm,10mm,etc. with necessary installation bits/tools) and how do they compare to TimeSerts, price,etc. ?
Offline CycleRanger
« Reply #7 on: March 28, 2024, 09:51:21 PM »
I got the step studs from https://belmetric.com/.
I used one of them on my XS650 a couple of years ago.
« Reply #8 on: March 29, 2024, 01:47:26 AM »
Keenserts dont have instalation kits, they use standard taps, maybe with an odd pitch, then just screw in and tap down pegs.
They do need quite a bit of metal round the hole, 6mm thread uses 10mm tap so 8 probably 12
« Reply #9 on: March 29, 2024, 12:09:19 PM »
I was waiting for Mark's answer as he presented what looked like a good product;seems I would have been waiting for a long time.
bryanj,Thank you for this information.
How have these Keenserts held-up in use,if you might know?
« Reply #11 on: March 29, 2024, 12:22:17 PM »
Definitely far better than helicoils.
How to install Keenserts
« Reply #12 on: March 29, 2024, 07:07:36 PM »
Depends on where you get them: I've installed many of them so I have their tools. I bought the first toolset at Grainger's, about half a century ago...
« Reply #13 on: March 30, 2024, 08:06:21 AM »
First keenserts i saw was in 75 being fitted into the studs/bolts for cam tower holding, never pulled out but did let a bit of oil down as nobody at the time was aware of the "blind" hole problem, thats how i know the 6mm inner has the 10mm tap but of the "odd" pitch that is not used much
« Reply #14 on: March 30, 2024, 08:11:35 AM »
Nice video on fitting/removing, never seen a proper tool, just screwed in and tapped tangs down, i seem to remember the smaller ones only having 2 tangs, but that was a very long time ago
« Reply #15 on: March 30, 2024, 09:33:48 AM »
Yep 2 tangs on the 6mm. That's what I remember, too.
I've used a lot more of the 8mm, with the 4.
« Reply #16 on: March 30, 2024, 10:02:39 AM »
I watched the video.
Offline LiveeviL81
  • Turbomatic
« Reply #17 on: April 01, 2024, 10:24:49 AM »
Appreciate all the help guys! Got the stud installed the other night and after waiting for all the locktite to set all weekend was able to get the exhaust on last night. My only worry will be if the stud unscrews when I go to loosen the exhaust in the future after the heat breaks down the Locktite. But unscrewing is a lot better than pulling threads out!
Kaleb
« Reply #18 on: April 01, 2024, 03:48:21 PM »
Which one did you decide to go-with Kaleb ?
Offline LiveeviL81
  • Turbomatic
« Reply #19 on: April 01, 2024, 06:54:44 PM »
Ended up putting in a 10mm helicoil and then purchased these https://www.amazon.com/dp/B0BZV1DR71?psc=1&ref=ppx_yo2ov_dt_b_product_details 10mm male to 8mm female inserts. Got both locktite-d in then installed the original 8mm studd with locktite as well. Was able to torque all of them to the same space (12ftlbs) and nothing else pulled out. If I did it again, I would probably bore all of the studs out to 10mm, helicoil and then get the 10mm-8mm step studs. Make it overkill so I could really torque stuff down.
Offline rotortiller
« Reply #20 on: April 02, 2024, 04:04:35 AM »
ended up putting in a 10mm helicoil and then purchased these
That should work fine and is much more than likely stronger than the original. A little anti-seize on the stud should prevent the inserts from screwing out during removal. That is kind of like a twinsert install. SS is way stronger than aluminum inserts and you now have a large thread surface in the base cylinder head metal. Nice to see you taking things in hand and thinking on your own.
« Last Edit: April 02, 2024, 04:32:24 AM by rotortiller »
