Author Topic: Aftermarket fork brace options for early 750Ks  (Read 1093 times)
Offline timtune
« on: April 06, 2024, 07:25:07 AM »
I know the fender works as a brace but I want to ditch it. I'm wondering about braces that mount to the top of slider.
Any thoughts?
Re: Aftermarket fork brace options for early 750Ks
« Reply #1 on: April 06, 2024, 07:37:54 AM »
Used to be common but doubt they are now
« Reply #2 on: April 06, 2024, 07:46:31 AM »
With no front fender I'd be worried about stuff being thrown at the fins. They are fairly delicate.
Online jonda500
« Reply #3 on: April 06, 2024, 05:47:57 PM »
Also riding in the rain can get problematic with water from the wheel getting flung up into the electrical parts under the tank..
John
A starter clutch thread:
« Reply #4 on: April 06, 2024, 07:59:45 PM »
John
Actually...at 70 MPH (or more) the water ends up right between one's eyes... ;) :(
Offline timtune
« Reply #5 on: April 09, 2024, 06:10:12 AM »
How bad is no fender no brace?
« Reply #6 on: April 09, 2024, 07:58:28 AM »
I don't think I'd want to find out, might be too exciting.
« Reply #7 on: April 09, 2024, 07:58:53 AM »
Dont want to find out at speed,the forks flex with the fender, hate to think of different flexing from each leg
Offline Galactica
« Reply #8 on: April 09, 2024, 07:59:47 AM »
Seems like Tarozzi makes one that will fit with no fender.
Offline spotty
« Reply #9 on: April 09, 2024, 07:20:59 PM »
i used to have a dunstall guard ( fibreglass, hose clamped to the top of the sliders) on my K2, which is about as stiff and bracing as a bowl of lukewarm custard, you could look down while riding on a rough road ( so most of the ones round here ) and watch the forks flex a couple of inches at the wheel end and not necessarily at the same time or rate
if you're worried about that sort of thing just don't look, didn't seem to make any difference to handling compared to having a steel guard, and to be honest at their peak these bikes handle like sh1t anyway, if you're after razor sharp levels then try a modern two wheeled anything, most uber delivery mopeds probably handle better
i blame Terry
« Reply #10 on: April 09, 2024, 08:43:06 PM »
The stock fender braces that were mounted in rubber bushings had absolutely Zero stiffening effect on the forks. ::) Even with the rubber bushings replaced with steel washers, the fender braces only had a slight effect, much less than a proper fork brace. ;)
Offline timtune
« Reply #11 on: April 10, 2024, 05:23:02 AM »
Ok so it looks like the Tarozzi 22-0037 will fit.
Iwill likely futz around trying to build my own and then break down and get the above.
« Reply #12 on: April 10, 2024, 05:27:20 AM »
That number is not for the CB750. Is is for the Suzuki GS750
https://www.caferacerwebshop.com/en/fork-brace-stabilisator-suzuki-gs-750-1977-24-0037.html
Offline timtune
« Reply #13 on: April 10, 2024, 06:29:52 AM »
That's the 24-0037, the 22-0037 is listed for the Honda 750
« Reply #14 on: April 10, 2024, 06:55:05 AM »
I believe that is the one I have on my K3 "Park Racer"
Offline Galactica
« Reply #15 on: April 10, 2024, 07:15:09 AM »
I had a Tarozzi on one of my KZ1000s.  It allowed the fender as well.  I’d be interested to hear of a fork brace on the CB750 that works with the fender as well.
« Reply #16 on: April 10, 2024, 08:32:00 AM »
 If you think you might want an old motorcycle part and see it offered for sale, don't wait. The next time you look they may be gone.
