Author Topic: Use Gasket Sealant?  (Read 825 times)
Offline Vintageguy
Use Gasket Sealant?
« on: April 18, 2024, 07:35:51 AM »
Going to replace the coil(s) cover on 1978 750F. Do I use a gasket sealant or not. Have seen info here not to use. Have seen a Youtube video where the person did use sealant. Do I use it or not? Thanks for any/all responses.
Re: Use Gasket Sealant?
« Reply #1 on: April 18, 2024, 08:01:01 AM »
Why woud yu use sealant under the tank? Or do you mean generator cover? If so NO just new gasket on clean surfaces with maybe clean grease to hold it on
« Reply #2 on: April 18, 2024, 08:04:06 AM »
Sealant is not used there, be sure it's very clean.
Offline Vintageguy
« Reply #3 on: April 18, 2024, 11:30:47 AM »
Thank you so much for the replies. No sealant. This website is always helpful without judgement.
« Reply #4 on: April 18, 2024, 12:21:41 PM »
Coil cover??? What is that??
Online BenelliSEI
« Reply #5 on: April 18, 2024, 01:07:25 PM »
Replacing the alternator cover? I hope you read all the replies we made to your questions back in January? I also added a write up for you in my K6 project file. Assuming you have another cover, it’s not just a case of unscrewing it and swapping them. A reply to all those previous responses you got would have been appreciated. Good luck with your project.
Offline M 750K6
« Reply #6 on: April 18, 2024, 03:12:41 PM »
Or, maybe means points cover?
Online BenelliSEI
« Reply #7 on: April 18, 2024, 03:36:30 PM »
Right…. Could be.
Offline Floshenbarnical
  • Money pit enjoyer
« Reply #8 on: April 18, 2024, 05:32:35 PM »
Following advice from people on here I scrape w a gasket knife, then file if necessary (tool marks, burrs etc) and lightly sand the area before wiping very clean and applying a few dabs of grease to hold the gasket in place. It’s good to be anal retentive when it comes to oil leaks … I didn’t mean for that to sound so disgusting, sorry
'77 CB750 SS
« Reply #9 on: April 18, 2024, 06:00:30 PM »
Shows a lot when we still dont know exactly what the op was talking about, just leaving us guessing
« Reply #10 on: April 18, 2024, 07:13:31 PM »
