Nice to hear from you Mike/Jerry....been a minute. I hope you both are doing well. Hopefully I'll be around on the forums more as I'm getting back into my bike projects now that the Jeep and firebird are all daily driver capable though never done
I got the exhaust all installed and did some test idling....I'll keep the competition baffle in there for now.
I am having some issues with it surging a bit at idle, and it doesn't want to idle much below 1000rpm. But the bike has never really been broken in. I think on its current motor setup it only has maybe 60 miles and a single dyno run. There was so much back and forth motor work over the last 4 years its hard to remember all the things Ron had going on.
Probably time to take a step back and double check all the ignition timing, plugs, and carbs. We have a set of 29mm Smoothbores on there now and I'll be honest I dont remember any of the jetting or needle settings. Currently it also does not have any connections to hook a balancer up to. So I think that's gonna be next on the list as time allows.
I have the RS34s from my other bike...but Ron was all about the smoothbores...so I'd like to get it running good with them if possible. I have zero experience with them at this point.
Joe
