Author Topic: Honda 750 K 2 battery help  (Read 359 times)
Offline jwurbel
« on: April 26, 2024, 03:51:09 PM »
Looking for replacement battery recommendations.  AGM preferred.  Last was a Duracell.  Lasted 8 months.  Anyone had luck with Motobat?
Thanks
« Last Edit: April 26, 2024, 05:04:26 PM by jwurbel »
Offline Ksgfx
Re: Honda 750 K 2 battery help
« Reply #1 on: April 26, 2024, 05:38:24 PM »
I have had great luck with Motobatt, not the cheapest but I have several of them in my bikes with the oldest going on 3 years now with minimal maintenance.
72 CB500 K2
70 CL350 K2
72 CB450 K5
73 CB450 K6
75 CB750 F0
« Reply #2 on: April 26, 2024, 06:47:20 PM »
I use the YUASA AGM. I just replaced it last year: the first one went almost 10 years! Outstanding performance, even when I forgot to give it the occasional 'winter bump' trickle charge: it sprang my steed to life effortlessly anyway.
I also put these in every SOHC4 I build, too.
I just put one into a 1979 CB650 that had a 2-year-old Duracell that was dead 0 volts after sitting last winter.
Offline jwurbel
« Reply #3 on: April 26, 2024, 07:26:17 PM »
Appreciate the answers.  I think I know which way to go.
Online newday777
« Reply #4 on: April 27, 2024, 03:32:20 AM »
Which is????
I have read the Motobatt is good but haven't sprung to try one yet but have thought about getting one on my project K6.
I have the Yuasa AGM in my K5, 3 years old now and doing great still.
I keep my batteries on a Schumacher 3 amp Smart charger Maintainer w/desulfication mode(reverse bump charge cycle to shake off sulfates) over the winters and occasional charging during the riding seasons to keep it up to snuff. I think my goldwing Yuasa AGM is 5 years old now.
Offline jwurbel
« Reply #5 on: April 27, 2024, 06:45:07 AM »
Opted for Yuasa after reading hear and other on line comments.
Have always kept them on a trickle charger.  Current Energizer shows 12.74 volts but under load drops to 12.2.
« Reply #6 on: April 27, 2024, 08:24:32 AM »
Here on Maui we get pretty short life from batteries. I start paying close attention when they are 3 years old no matter the brand, after that failure could be any time.
I have a Battery Tender on my K3, going great after 3 years, time will tell.
« Reply #7 on: April 27, 2024, 10:44:30 AM »
Typically, more than 5% voltage drop under moderate load tells that the lead is losing free electrons. This is normal wear, as opposed to 'sulphation' issues, which is when the lead gets oxidized by other elements like impurities from the lead alloy used, itself. The purer the lead, the less there is to attack it. Keeping a steady trickle charge on the battery tends to break the lead down on the (+) side of the plates, which is where the electrons exit to circulate thru the charger (electrical current) as the 'new' electrons (from that charger) attach to the other face of that lead plate. The new arrivals are not chemically identical to the original lead, so some inefficiency results from being left on chargers constantly, shortening life overall. We learned this back in the 1960s and 1970s.
This led to the spiral-wound 'minichamber' technology where the chemistry is actually captured in hundreds (or thousands in car batteries) of little cells, rectangular chambers that were punched into lead sheet, making them look perforated with little rectangles. Then the conductive metal layers (+ pole and - pole) were laid onto the perf'ed lead, filled with acid, and rolled up into a shape like a soda (or beer) can. These became known as the '6-pack' batteries in the 12 volt versions, as each wrapped can was 2.2 volts after charging. These versions last decades, in my experience (heck, the one in my motorhome is 30+ years old and works fine, still) and if they hadn't been "knocked off" into something cheaper (using worn, recycled lead) in Mexico when the bike versions appeared around 2005 or so, they would still be great today. The Japanese picked up on the closed-cell construction, though, and used fiberglass mat in little rectangle shapes to hold the acid in between two lead sheets (sort of an inside-out version of the wound cell) and the AGM version was born. For bikes, this is about the most efficient battery we can get right now.
