Author Topic: Shifter Cover Install Procedure  (Read 590 times)
Offline Vintageguy
« on: April 28, 2024, 06:42:47 AM »
I know this is crazy, but can't get the shifter cover on to my 1978 750F. I have filed it to fit as much as I dare, and still have about 1/8 of an inch to go to bottom out. I just do not understand this. Can anyone please provide me with the proper install steps. Thanks.
Re: Shifter Cover Install Procedure
« Reply #1 on: April 28, 2024, 07:47:35 AM »
Have you by any chance a dowel in the cover AND a dowel in the casig?
« Reply #2 on: April 28, 2024, 07:50:27 AM »
Does the dowel fit easily in both sides?
If you have a spare dowel you can check the empty side.
Offline Vintageguy
« Reply #3 on: April 28, 2024, 08:17:29 AM »
There is a dowel in the case AND a dowel in the shifter body. Yes.
Offline Vintageguy
« Reply #4 on: April 28, 2024, 08:54:44 AM »
Are the dowels absolutely necessary, and are they removeable? Are they supposed to be in the case, or the cover? Thank you.
« Reply #5 on: April 28, 2024, 08:55:48 AM »
Hopefully in different holes
Offline Vintageguy
« Reply #6 on: April 28, 2024, 09:56:51 AM »
where are the dowels supposed to be?
« Reply #7 on: April 28, 2024, 10:45:30 AM »
Old dowels often in need of grinding off dirt and marks, grit 400 paper. If oval shape, replace it. I ordered several dovels years ago.
This dovel same size as under cam towers.
Cover hole can have marks so dovel will not fit.
Aftermarket gasket usually fit bad.
Some holes need to be widened
with a sharp knife since hole pattern is wrong.
Here a cover to a CB750 K6
2 dowels.
« Last Edit: April 28, 2024, 10:52:39 AM by PeWe »
Online grcamna2
« Reply #8 on: April 28, 2024, 12:24:51 PM »
You should have only one dowel per hole;the problem may be if a 2nd one was already jambed in there and it creates a gap,it can cause sealing issues on the gasket surfaces.
« Last Edit: April 28, 2024, 12:27:07 PM by grcamna2 »
« Reply #9 on: April 29, 2024, 02:34:06 AM »
Wherever dowels are used, there will be bigger diameter bore for the dowels to fit in, matching holes in the engine case. It's not rocket science. Look closely at the holes for the difference.
As per said, check the condition of the dowels that they are round and not out of shape, dinged, rusted. Clean up the dowels or replace them as needed. The dowels are wear items to replace as needed. They are to locate the gasket in the proper position.
Offline Vintageguy
« Reply #10 on: April 29, 2024, 04:38:36 AM »
This cover does not seem to fit, irrespective of dowels. It won't fit on, even with the dowels removed. I'm quite certain that the stator housing I purchased is the correct one, and the shifter cover has been on for 46 years. I have been riding and working on bikes for 55 years. I'm totally confused as to why the cover will not fit on. FRUSTRATED.
Offline Lucien Harpress
« Reply #11 on: April 29, 2024, 05:33:32 AM »
Check the wire that goes down to the neutral light switch.  It's crammed into an impossibly narrow gap between the stator and shift covers, and is very easy to pinch.  I struggled with that for quite a bit before I got my covers to lie flat.
-1970 CB750 K0
-1980 KZ1300
-1976 Yellow GL1000
-1965 CA77 "Dream"
-1997 Valkyrie
-1975 Velosolex
« Reply #12 on: April 29, 2024, 01:01:19 PM »
Did someone fit washers behind the stator? That would cause the stator to be the thickness of the washer out of place and that could cause your problem...
« Reply #13 on: April 29, 2024, 01:43:48 PM »
So you say the shifter cover has been on for 46 years yet it doesn't fit now?? I'm confused.......
Offline denward17
« Reply #14 on: April 29, 2024, 02:01:59 PM »
I do know there is a trick to getting the cover on the '78 K.  Maybe that is what he is running into.
Has to be installed at a certain angle.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #15 on: April 29, 2024, 05:23:04 PM »
The sprocket cover requires a "twist of the wrist", while the shifter (transmission) cover is a straightforward install. Did you remove/reinstall any shifter components that may now be interfering? Some pictures might help.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
