Author Topic: A Quick Question  (Read 782 times)
Offline Vintageguy
A Quick Question
« on: May 04, 2024, 06:43:57 AM »
Has anyone ever had to put a shift cover on with a rubber mallet? Shouldn't the cover lie flat against the gearbox? Thanks.
Re: A Quick Question
« Reply #1 on: May 04, 2024, 07:03:56 AM »
Not on a cb750. It needs a little bit wiggling.
If using force, something will be damaged. Try without knock pins.
If that work, focus on them.
A bad gasket can stop them. Or the harness, shifter shaft etc.u
Offline Vintageguy
« Reply #2 on: May 04, 2024, 07:10:58 AM »
I took ScotchBrite to the dowel pins, and they are clean clean. Not the issue. The cover will not go on irrespective of wiggling. This ocver has been on for 46 years before now. Never had a problem like this. Think I need a drink.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #3 on: May 04, 2024, 07:54:59 AM »
Perhaps some close pictures?
1973 CB 750 K3
10/72 build Z1 Kawasaki
