Author Topic: Installing dyna S today..  (Read 2684 times)
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« on: March 18, 2007, 09:49:33 AM »
And I need to know what size the big hex is for turning the crankshaft to set static timing with.
No.
Offline medic09
Re: Installing dyna S today..
« Reply #1 on: March 18, 2007, 09:53:46 AM »
I'm pretty sure that on my '78 750 it's 23mm.
Have a good time!  ;D
Mordechai
'78 CB750K
'07 aprilia Caponord
Santa Fe, NM
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #2 on: March 18, 2007, 09:54:44 AM »
Sweet, thanks!
No.
« Reply #3 on: March 18, 2007, 10:57:30 AM »
The wrench I use says cresent on it.
 ;D
Offline medic09
« Reply #4 on: March 18, 2007, 11:02:17 AM »
I used a Crescent the first few times I played in there.  Then one day the wife says "I'm going to Sears, do you want anything?".
I love it when she says that!   ;D
Mordechai
'78 CB750K
Santa Fe, NM
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #5 on: March 18, 2007, 12:02:59 PM »
mark--are you doing it at home? i'll be at the shop at some point this afternoon if you want help. call me if you want to figure out a time as i'll be out most of the day riding.  ;D
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline mrbreeze
  • Not your average
« Reply #6 on: March 18, 2007, 12:06:24 PM »
I never realized until last week that these bikes use 23mm bolts for things.I was taking the fork tube caps off and the only socket I had to fit was a 15/16 which was a loose fit but worked. My metric sockets don't include a 23mm so off to Sears we go!!!!
MEMBER # 257
Offline paulages
  • 1976 cb735
« Reply #7 on: March 18, 2007, 01:37:03 PM »
i bought a 23mm wrench just for that purpose, but sharing a shop with 7 other people (most of whom have sohc hondas) means it is constantly missing...  ::)
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline doug_id
    • My Cafe 550 Project Gallery
« Reply #8 on: March 18, 2007, 01:57:07 PM »
Cool...let us know how the install goes and if you notice any difference in how it runs.   I will probably be installing at some point as well.   ;D
02 Concours
78 CB550
06 Stella 150 2t Scooter
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #9 on: March 18, 2007, 03:05:59 PM »
Was an easy install. Went smoothly. My points needed replacing anyway, 2 and 3 were adjusted as far as they could go and were still a bit too advanced.
Runs well, though only took it up to 6k here on my block.
Hey Paul, I'll want to come by this week and do timing. I only did static timing, let me know when a good day is.
Used a 23mm socket, worked great.
I did NOT do the dyna coils, this is with stock coils. I will be adding dyna coils and plugs wires next month, finances allowing.
No.
Offline paulages
  • 1976 cb735
« Reply #10 on: March 18, 2007, 03:08:07 PM »
i'll let you know when i'll be there mark. in my experience, static timing done well ends up dead on when checked dynamically, as long as the advance unit is functioning properly. hope it runs better...
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #11 on: March 18, 2007, 05:49:22 PM »
It's running pretty good now. Now that riming is good, and valves are adjusted, I can finally start fine tuning these damned carbs :P
No.
« Reply #12 on: March 18, 2007, 05:56:07 PM »
Now that riming is good...
Er, you might be in the wrong forum for that discussion...:o
 :-X
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #13 on: March 18, 2007, 08:02:42 PM »
 :-X
er, whoops.
*tming*
No.
Andoo
« Reply #14 on: March 18, 2007, 08:31:16 PM »
You can also use the Honda Tool kit wrench. Comes with the bike =)
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #15 on: March 18, 2007, 08:35:18 PM »
Not with mine, it didn't. I'm sure that disappeared sometime in the early 70's.
No.
« Reply #16 on: March 19, 2007, 08:17:53 PM »
Mark, we don't have a 23mm nut because the end of the crank has been removed for lightness.
A few weeks ago when we did the riming or *tming* which ever you prefer :D :D :D :D :D  we put it in top gear and turned the rear wheel slowly,....worked a treat  ;D ;D ;D ;D
Sam.  ;)
« Reply #17 on: March 19, 2007, 10:46:04 PM »
How about just bumping the kick starter?! Sure is handy and on the same side too.
« Reply #18 on: March 19, 2007, 11:05:12 PM »
What kick starter ?  ;D ;D ;D ;D ;D ;D ;D ;D
Sam. ;)
« Last Edit: March 19, 2007, 11:09:40 PM by samcr750 »
