I did not know whether to keep this thread going with all that I need to do or start new... Perhaps when this gets too crowded then I'll diversify.
So, first off... the new bars arrived, and I started to pull the waaaay too tall bars off and the wiring is a puzzle or actually, the process of changing the switch wires is.
I started with the right side and promptly pulled the connector out of the switch... great. I cannot see repairing that connector, it looks a bit butchered and repaired in there plus the shorter bars are going to require shorter wires so I suppose replacement is the way to go.
Now, I have no problem with buying spendy OEM switches even though they are pricey. Are the aftermarket switches of decent quality...? Good wire connectors and appropriate length etc...?
Secondly, When pulling the wires out of the headlight bucket, what is the preferred method..? I can look at the wiring diagram and pull each wire from the connectors in the bucket but... is that the way to do it...? I Really hate the idea of pulling the gauges and all that.
I actually am not in love with the idea of running the wires for a new switch through the bar but, probably must.
Right hand switch connector...
Connector clip in the switch housing...
Your basic headlight full of wires and connectors...
And as a side note, do I need to disturb the dash light board...? Not certain if you can make it out here, that bale seems to hold the light sockets in place.
All right, thanks much,
Rob
