Author Topic: CB750 K1 Starter Issue  (Read 516 times)
Offline SoCalHarley
« on: May 12, 2024, 07:21:06 AM »
My K1 starter suddenly stopped working after sitting for a few months without starting it.  Battery 100%.  I can hear the solenoid making the humming sound but starter not spinning.  Any suggestions before I pull the starter out.
Thanks
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: CB750 K1 Starter Issue
« Reply #1 on: May 12, 2024, 08:01:38 AM »
Check voltage at the starter, you may have a wire problem.
They are not hard to remove for checking.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline SoCalHarley
« Reply #2 on: May 12, 2024, 08:16:07 AM »
Thanks.  Interesting there was no problem but after sitting the problem occurred.  I'll pull it out and check. Anything else it may be?
Offline BenelliSEI
  • 1969 cb750
« Reply #3 on: May 12, 2024, 08:18:16 AM »
Sure about your battery? Sounds dead tome……
« Reply #4 on: May 12, 2024, 08:47:47 AM »
The solenoid making a humming or buzzing sound instead of a single click is a classic sign of a bad battery.
Offline SoCalHarley
« Reply #5 on: May 12, 2024, 09:41:40 AM »
I had it on a trickle charger but then tried my Battery Charger and it showed 100%.  Started right up with the kick starter and ran perfectly.
« Reply #6 on: May 12, 2024, 09:55:32 AM »
Check the battery voltage with a meter, then press the starter button and see how much the voltage drops. ;)
Offline SoCalHarley
« Reply #7 on: May 12, 2024, 09:58:48 AM »
I Just checked the voltage with a meter and the voltage drops off dramatically when I hit the starter.  Even though it is showing fully charged it looks like the battery is bad.  I have not seen this before so that is why it was confusing to me.  Thanks for your help.
I was using a BikeMaster Platinum AGM MS12-14L-A2 previously that lasted for several years.  Any suggestions for a replacement.
« Last Edit: May 12, 2024, 10:04:43 AM by SoCalHarley »
Offline denward17
« Reply #8 on: May 12, 2024, 10:18:03 AM »
^Sounds like my 550 when the starter went bad.
Offline SoCalHarley
« Reply #9 on: May 12, 2024, 10:32:22 AM »
I just tried a jump pack I have for my Harley and it cranked right over.  Definitely the battery.
Offline SoCalHarley
« Reply #10 on: May 12, 2024, 10:56:23 AM »
Offline newday777
« Reply #11 on: May 12, 2024, 11:08:27 AM »
Yuasa or Motobatt are good choices in AGM
Stu
My current rides
Prior bikes....
