So I just reinstalled my carbs on my 76 550 after having them off to check float height levels as I have never done that in this bike. They were indeed off. While they were off I bench synced them. I followed guides on here and I’m almost positive I have it right. (I haven’t started the bike yet) but I designated #2 carb as my reference carb, backed idle adjuster all the way off, set number 2 slide bottomed out, raised idle knob to fit drill bit. Set the rest using the adjusters. I made sure the slides bottomed out when the idle was turned out.
My question is, when installing I realized that even with the idle adjuster all the way backed out. I noticed that the bell tank where the cables attach Doesn’t make contact with the pin on the cable mounting bracket. Even after I turned it. How important is it that it makes contact? Also. Can I just loosen the bolts and clock the bell crank so it makes contact? I included a picture of the linkage BEFORE I took it off the bike. Where it was making contact, just so you guys know what I’m taking about
