Author Topic: Can you cut a fork oil seal? (Hail Mary options)  (Read 850 times)
Offline Brycelyoung
« on: May 18, 2024, 10:52:31 AM »
First time disassembling the forks on my 1979 CB650. Everything good, but now I'm down to removing the oil seals and neither one will budge. Tried a screwdriver (lol), hammer claw, bought a seal puller, tried heating them up....there is no evidence that I've even touched them, they just haven't moved at all.
I'm at my whit's end, close to taking them to a dealer, but wondered if it would be possible to cut them out with a mini-cutoff wheel with a Dremel. Any other tips I've missed?
Seen every video and online tutorial I can find, and they all say, "These are tough, but just be patient and you'll get it." har har
Re: Can you cut a fork oil seal? (Hail Mary options)
« Reply #1 on: May 18, 2024, 01:02:28 PM »
Have you taken the wire circlips out
Offline Brycelyoung
« Reply #2 on: May 18, 2024, 02:10:40 PM »
Yes, I have.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #3 on: May 18, 2024, 03:26:23 PM »
I made a tool to remove the seals from the fork lowers. I scrounged up what looks like an automotive shock absorber washer (stepped profile) that was almost the same o.d. as the seal. I then squared two sides of the washer so I could "see-saw" the washer in behind the seal after welding a 3/8"-16 nut to the backside of the washer. A big ol' washer on top of the fork and a bolt through the nut behind the washer that is behind the seal and I have yet to find a seal that could resist this type of persuasion. If I can find the tool (without too much effort) I'll post a pic.
EZPZ  8)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline craz1
  • CDA, Idaho
« Reply #4 on: May 18, 2024, 03:58:15 PM »
Here is what I use. Its basically a tire iron with a plastic protector that is used on the rims when removing tires but any plastic would work
Never has failed or damaged the top of the fork tube. You can use a bit of heat on those really old (40-50 years) ones we tend to find on these older bikes
74 CB550,73 Z1900, 74 Z1900, 75 Z1900,
72 XS2650, 73 RD350, 2013 FJR1300, 84 XJ550 YAM
Offline scunny
  • don't call me expert
« Reply #5 on: May 18, 2024, 04:53:56 PM »
Boil a pot of water, place fork leg in seal down. leave for a few minutes, then carry out craz1 plan.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline BenelliSEI
  • 1969 cb750
« Reply #6 on: May 18, 2024, 07:55:03 PM »
I punch/screw two drywall screws (they are very sharp) down into the seal top, 180 degrees apart. Then protect the fork leg top with a scrap of plastic or wood, and pry up on the screw head with a nail puller (small crow bar with a nail pulling head).
« Reply #7 on: May 18, 2024, 07:57:05 PM »
I also use a tire iron with a piece of plastic to protect the top of the fork, but my iron is more curved than craz1's, which makes for a better angle of attack. :)
Offline Brycelyoung
« Reply #8 on: May 18, 2024, 09:20:20 PM »
This one I actually tried a couple times. Never made any difference. I finally did get them out—using a propane torch I just blasted them to hell.
Offline Brycelyoung
« Reply #9 on: May 18, 2024, 09:23:13 PM »
Ah, this makes sense—I hope I will not have to give it a try again any time soon. :)
« Reply #10 on: May 18, 2024, 11:51:03 PM »
Tire iron after heating the fork outside with a heat gun.
A little bending from different sides to avoid cracking the aluminium.
Offline rotortiller
« Reply #11 on: May 22, 2024, 01:18:21 PM »
I use hydraulics to pop them. Take the spring out, add fluid, install the fork cap and compress the shock with a press or something. Massive prying etc not required.
Offline Floshenbarnical
  • Money pit enjoyer
« Reply #12 on: May 22, 2024, 06:57:52 PM »
+1 for tire iron. Only thing that would shift mine. I put a rolled up micro fiber cloth under the iron to prevent marring the form upper.
"All things change in a dynamic environment. Your effort to remain what you are is what limits you."
'77 CB750 SS
Offline Alan F.
« Reply #13 on: May 22, 2024, 08:31:46 PM »
First time I removed 50 year old fork seals I drilled 3 small holes in the top of the metal body of the seal and threaded in 3 drywall screws, I used a flat washer slipped between the seal and the bottom of the seal bore for each screw to bottom against, then I screwed the drywall screws in a half turn each until the seal began to rise.
Adding heat to this method may be an improvement. If a screw pulls out thread in a fatter screw.
