« Reply #1 on: May 19, 2024, 05:13:39 AM »
Sean had a similar problem when he arrived in New Hampshire. He thought it was the clutch too. He pulled it apart and everything was in spec with the clutch. Readjusted and still had the problem. Andy750 sent a message that he had a similar issue in Austria going up a mountain. He found a loose screw on the shifter drum end in the shifter/transmission cover.
I noticed a rattling in the shifter side while I was there shifting the bike at idle on the centerstand (and wondered if something was amiss in the shift linkage)
Sean popped off the tranny cover and sure enough that screw was loose on his. It was allowing the shift linkage to not shift fully into the gears. We cleaned up the threads on the wire wheel, put some blue loctite on and tightened it up. As far as I know that fixed it still.
« Last Edit: May 19, 2024, 05:16:17 AM by newday777 »
![](http://forums.sohc4.net/Themes/default/images/ip.gif)
Logged
