Author Topic: Dimple porting  (Read 1435 times)
Offline 1080
Dimple porting
« on: May 25, 2024, 07:59:34 PM »
Dimple porting has any one tried?
Offline 1080
Re: Dimple porting
« Reply #1 on: May 25, 2024, 08:08:55 PM »
Re: Dimple porting
« Reply #2 on: May 25, 2024, 09:27:59 PM »
Following
Offline 1080
Re: Dimple porting
« Reply #3 on: May 27, 2024, 09:32:59 PM »
Offline spotty
Re: Dimple porting
« Reply #4 on: May 28, 2024, 07:19:49 PM »
similar to what BMW used on their first generation of helmets, universally known as golf ball helmets, they claimed it reduced turbulence. the idea came from golf balls which travel much further and straighter with the dimples they have. a golf ball with no dimples is demonstrably weaker in accuracy and distance
maybe in an intake port it promotes speeding up ( or less resistance ) of the charge. i think the principle was that air will hit the far edge of the dimple, circle round and when it comes out takes any passing charge with it. could be wrong but my failing memory tells me something like that
i blame Terry
Online HondaMan
Re: Dimple porting
« Reply #5 on: May 28, 2024, 08:24:12 PM »
The dimples reduce the friction of the air in close proximity to the port's surfaces. When air flows thru a tube it flows in a laminar fashion with the air moving slower and slower as it gets closer to the walls of the tube it is traveling. The dimples reduce the static slow air layer's thickness, making the same diameter tube act as if it were larger diameter. In aviation designs, this is a well-known 'secret'.
Those "Myth Buster" guys once did a car all over with the (baseball-sized) dimples to see what happened. They got better gas mileage for their efforts!
Offline spotty
Re: Dimple porting
« Reply #6 on: May 28, 2024, 09:34:20 PM »
well there you go, my entire second sentence was wrong, no major surprise there, its a universally acknowledged truth that i'm thick as pigsh1t and i'll be the first to admit it
i blame Terry
