Logo merchandise is available at the SOHC/4 Shop
I've never torqued any of these nuts - just use the reasonably tight method once I feel the gasket crushing down. I do check them after a few heat cycles and usually nip them up a little more. They only have to hold the header / gasket firmly in place so that they don't leak.If they are 6mm then 8-9 ft lbs is correct if you want to be certain.
