Author Topic: CB350F 1974 Extra Piece  (Read 951 times)
Offline The Lone Builder
  • "Still running against the wind"
    • Belfast-2-Belfast-By-Bike
« on: June 02, 2024, 07:15:45 PM »
While waiting to recover my regulator from USPS, I’m helping my host here in Greencastle with his 350F. The bike has sat for several years and he doesn’t think the engine has been taken apart before.
He tells me that when he dropped the oil pan, he found the attached part in it. I think this as a cap from the clutch outer in the primary sprocket.
How could this have got there without previously dismantling the engine?
Is it possible this just dropped out while he was taking things apart? He didn’t dismantle the sprocket assembly.
And most importantly, if this is not something that has recently dropped out, what will happen if he just continues - the engine is closed up again – and runs the engine?
CB750 K2 - From Belfast-2-Belfast
CB750 K1 - The less, said the better!
CB450 K1 - Stalled.
CB400F Supersport - Not Rusty any more!
Follow my journey through Africa @ http://Belfast2BelfastByBike.com
Re: CB350F 1974 Extra Piece
« Reply #1 on: June 03, 2024, 02:08:24 AM »
Is it hollow with one end capped or is it solid?
Online jaytee-nz
« Reply #2 on: June 03, 2024, 02:36:52 AM »
Looks like an oil control jet like the CB500/550 ones but it's different to the CB350 one, so maybe not ?
« Reply #3 on: June 03, 2024, 09:04:23 AM »
It’s hollow. And looks just like the part on CMS - 28126-253-030
CB450 K1 - Stalled.
« Reply #4 on: June 03, 2024, 12:19:38 PM »
I think it is the cap that goes between the spring and roller in the starter clutch, to check the motor has to be split
Offline Nurse Julie
« Reply #5 on: June 03, 2024, 02:05:15 PM »
Definitely looks like it's from starter clutch.
Here's one in my 400/4
« Last Edit: June 03, 2024, 02:16:52 PM by Nurse Julie »
Trust me I'm a Nurse, I promise it won't hurt....much
« Reply #7 on: June 03, 2024, 05:51:02 PM »
The real question is what might happen if he starts the motor and it is missing? Presumably the spring and roller would be missing also.
He is certain he didn’t dismantle any of the transmission shafts and is almost certain the engine has never been apart before.
So the second question is whether there is a way this could have fallen out and into the pan?
CB450 K1 - Stalled.
Offline 69cb750
« Reply #8 on: June 03, 2024, 06:57:19 PM »
The only way to know what is there is inspection.
The starter clutch was apart by someone in the past.
« Reply #9 on: June 03, 2024, 07:14:35 PM »
There's only a small hole (about 3/4" or 19mm) diameter that I remember at the bottom of the engine case on the alternator's side, under that cover. It could possibly give a path for the starter plunger to make it to the tranny, but it's quite a long and hilly trip. I guess oil could push it along, though, if it made it to that hole.
« Reply #10 on: June 03, 2024, 07:26:24 PM »
It can only come out if the roller is removed and that needs the gear removed so it has to have been apart
« Reply #11 on: June 04, 2024, 04:24:56 AM »
K, thanks all.
I’ll see what he decides to do.
CB450 K1 - Stalled.
