Author Topic: 1983 Nighthawk 650 Oil Cooler and Adapter is a No-Go  (Read 584 times)
Offline pekingduck
« on: June 04, 2024, 03:28:46 PM »
I've run across some threads on this and other forums suggesting the very inexpensive and compact oil cooler adaptor from the DOHC model could be used on our CB500-550-650-750s.
I found that the adaptor plate, while using the same o-ring and 20mm diameter oil filter bolt, will not physically fit without some machining, and rotating it 180 degrees so the inlet/outlet ports point down 45 degrees. It can be done, but a wormhole maybe best not pursued.
Any source for inexpensive oil filter adaptors?
Offline grcamna2
Re: 1983 Nighthawk 650 Oil Cooler and Adapter is a No-Go
« Reply #1 on: June 04, 2024, 10:05:15 PM »
'Terry from Australia' member here will know;send him a PM.
75' CB400F/'bunch o' parts'
Offline pekingduck
« Reply #2 on: June 06, 2024, 10:25:51 AM »
Thanks.  I should have put this in this forum, which has lots of info.
http://forums.sohc4.net/index.php/topic,166.0.html
Offline Nicklopic
  • New York
« Reply #3 on: June 06, 2024, 10:28:46 AM »
TTR400 from 4into1
Rippe rock racers also makes an adapter but it takes a spin on filter
forums.sohc4.net/index.php/topic,195055.msg2286430.html#msg2286430
80' CB650
Build Thread
