Author Topic: Moto Martin GSX 1260 -82  (Read 12106 times)
Offline DME
Re: Moto Martin GSX 1260 -82
« Reply #75 on: April 02, 2025, 12:59:03 AM »
Looks like a very pleasing body piece and fits your frame,etc.  8)
Will you be able to tuck behind it without needing to slide back on the seat too much ?
if its got the original Moto Martin seat on it there ain't nowhere to slide to
I think that is generally the idea
Exactly, there will be no sliding in any way, shape or form in this seat  ;D
« Last Edit: November 16, 2025, 12:47:08 PM by DME »
« Reply #76 on: April 02, 2025, 09:20:28 AM »
The shield on the front fairing in the picture above looks to be cut-open to allow the rider to tuck-flat into it's design.
Offline DME
« Reply #77 on: April 20, 2025, 06:08:46 AM »
New tires arrived this week.
As the front wheel now is changed from 16" to 17" new front rubber was needed.
As for the rear it is good as new threadwise, but has been sitting for over two decades...
The plan is to find a newer GSXR rear rim as they are slightly wider than tihe one fitted now.
Also recieved the materials needed to manufacture the new fairing and headlight stays.
They need to be slightly different than the stays for the full fairing, and I do not want to modify the current one should I want to switch back to the full fairing.
So, a new one has to be manufactured and as I couldnt decide between aluminium or stainless I picked up material for both... ;)
And as the snow has melted away quite early this year, the two Yamahas are now primed and ready for the summer  :D
Next up is to give the CB750 an oilchange and a checkup  :)
« Last Edit: November 16, 2025, 12:53:53 PM by DME »
Offline DME
« Reply #78 on: May 09, 2025, 01:35:15 PM »
Fitted the new front tire this evening, and with the front wheel back on the Martin is now back on its feet.
The visual difference from the dragrace setup it was in when I picked it up and the street setup I'm taking it back to is quite striking  8)
« Last Edit: November 16, 2025, 12:57:09 PM by DME »
Online BenelliSEI
« Reply #79 on: May 09, 2025, 02:35:04 PM »
Very different! Looks great.
« Reply #80 on: May 10, 2025, 07:39:04 AM »
Lots of rubber on the road!!
« Reply #81 on: May 10, 2025, 10:44:13 AM »
That's a great engine. Gotten them into the 180RWHP range and they are bullet proof after welding the crank.
Offline DME
« Reply #82 on: May 10, 2025, 02:32:15 PM »
This particular engine is from 1981 so it originally came with the small 25mm alternator big end.
When the engine was resleeved and taken up to 1260cc the crank was welded and the big end was replaced with the beefier  29mm big end from a 1984 1150 engine  :)
The builder/previous owner never had it on the dyno so the actual output is so far unknown, but to be able to run consecutive 9.7-second runs on the quarter mile should put it somewhere around 160-ish RWHP I guess...?
« Reply #83 on: May 11, 2025, 12:37:20 PM »
Good move replacing the alt end. God....there were so many combinations for those eng involving alt ends, starting clutch drives etc....PITA. Anyway....160RWHP is very doable. My FJ1200 (1314cc) is in that range though it is harder to get the FJ (or DOHC Honda) engine in that range. The TSCC cylinder head is far superior to the FJ/DOHC heads.
Offline DME
« Reply #84 on: May 12, 2025, 05:31:32 AM »
Well yes, it is a well setup engine that probably will work good back on the street too.
To have the full history from the builder is of course a very good thing, and so far all my questions has been answered.
There are pretty much just one questionmark left, and that is what the cams are...
I know they are Norris cams, but I don´t know what model and the builder doesn´t remember.
I´ve got his measurements and his notes from when the cams were fitted and degreed, but nowhere has he noted the model.
Oh well, I´ll check for any signs of numbers or anything else when I´ll lift the camcover, and if I don´t find anything it´ll be an unknown...
Offline DME
« Reply #85 on: May 30, 2025, 02:31:03 AM »
Found a couple of minutes to mount the tank/seat-unit the other day.
It´s still a looong ways to go, but it´s always good to get a visual reference of the mods I´ve done so far... and I do really like where this is going  :D
« Last Edit: November 16, 2025, 01:01:23 PM by DME »
« Reply #86 on: May 30, 2025, 07:42:28 AM »
That is a radical frame setup!
Offline DME
« Reply #87 on: June 07, 2025, 03:56:41 AM »
Started the process of mocking up the new half fairing.
Will need some more fine adjustments but this is pretty close to the final placement  :)
« Last Edit: November 16, 2025, 01:04:36 PM by DME »
« Reply #88 on: June 07, 2025, 09:02:01 AM »
Nice  :)
What will the windshield look like when mounted ?
Offline DME
« Reply #89 on: June 09, 2025, 04:08:22 AM »
Nice  :)
Here's a couple of pics that illustrates the difference between the dragrace-setup with the full fairing I picked it up in and what it looks like right now with the screen  :)
« Last Edit: November 16, 2025, 01:07:18 PM by DME »
Offline DME
« Reply #90 on: October 26, 2025, 07:57:40 AM »
Picked up a 5.5" wide GSXR rear rim to replace the 4.5" wide GSXR rim that was fitted by the previous owner/builder.
Wasn't sure if it would be possible to squeeze another inch in , but after some careful measuring and a testfit it will work fine  :D
This will allow me to run a 180 tire instead of the 160 that is what goes on a 4.5" rim.
« Reply #91 on: October 26, 2025, 08:02:08 AM »
Good to see the 5.5" will fit;you have many options of 180 rear tires.
Offline DME
« Reply #92 on: October 27, 2025, 05:27:41 AM »
Hmm... seems as if all attached pics has disappeared from this topic, except for the five pics I posted yesterday.
Or at least I cant see them anymore... can anyone else?
Is there a moderator or support I can contact to find out what has happened?
Offline denward17
« Reply #93 on: October 27, 2025, 05:46:43 AM »
http://forums.sohc4.net/index.php/topic,206017.0.html
Offline DME
« Reply #94 on: November 16, 2025, 01:13:16 PM »
Found some time and spent it on getting all the missing pics back up again  :)
The new rear wheel is in the process of getting made to fit, more info on that coming soon...
« Reply #95 on: November 16, 2025, 06:29:17 PM »
 8)
 8) :)
Offline DME
« Reply #96 on: November 21, 2025, 02:47:03 AM »
The quest to make room for the wider rear rim continues.
Recieved the 525 chain yesterday and immediately set about thinning the new JT 530 front sprocket to correct width.
Good and hard material in the sprocket  8)
The weekend will be spent lining everything up, making the required spacers for the wheel etc...
Online BenelliSEI
« Reply #97 on: November 21, 2025, 06:32:12 AM »
“The devil is in the details”! Nice work.
« Reply #98 on: November 21, 2025, 08:18:58 AM »
Did you use a special-type Carbide tool to thin that sprocket ?
