Author Topic: Master Cylinder Problems?  (Read 1562 times)
Offline LoopsAndLogic
  • Dang IT!!!
« on: March 19, 2007, 09:10:43 am »
After rebuilding my master cylinder on my 1981 CB650C, I find that the master cylinder won't push any fluid.
I use my vacuum gauge at the caliper and no fluid will drain down through the hoses. Then I try pumping the system, and I get no pressure.
 I then take the master cylinder off and while it's in my hand I push down onto the brake lever and no fluid will even come out of the banjo opening.
 Before I installed the K&L rebuild kit, the bore was completely smooth with no visible nicks at all.
 The M/C is full of fluid and I was wondering if I need to have the top cap off when I'm priming the system??
Should some fluid come out into my hand when I squeeze the lever??
 Right now I'm at a stand still.  And the master cylinder is the dual caliper type.  Could I have the wrong K&L kit??
Thank you
My rides:
75' 76' Honda CB400F Super Sports
86' Honda XR600R for Street Madness
84' Honda Interceptor VF500
Past Rides:
80' Honda CX500C Fully Dressed
81' Honda CB650C very nice!
83' Kawasaki KZ550 A3
78' Hondamatic 400 Hawk
80' 81' 82' Honda GL500 Silverwing Insterstate
Re: Master Cylinder Problems?
« Reply #1 on: March 19, 2007, 09:20:25 am »
First wear protective gloves!!!!! VERY IMPORTANT
leave the master bolted to the bars
Fill the reservoir
remove the outlet banjo
put finger, protected by glove, over the outlet hole sealing the hole
(1)pull in and hold lever
(2)lift off finger and replace
(3)release lever
Repeat (1), (2) and (3) until fluid starts pumping then whilst holding in lever refit pipe and banjo
Might sound crazy but after years of practice believe me it works
  • Dang IT!!!
« Reply #2 on: March 19, 2007, 04:16:27 pm »
Thanks! Will try that tomorrow or Wednesday.
I've never had to do this before. Could you explain what I am doing wrong?
My rides:
Past Rides:
Offline Hockers Choppers
  • go away winter!!!
« Reply #3 on: March 19, 2007, 07:11:06 pm »
I'd check the rubber plunger in the m/c. I used a rebuild kit one time and the skirt on the plunger was too long and it sealed off the hole that the fluid goes thru from the reservoir. Do You still have the original one to compare it too?
The thing about common sense is that, it's not that common.
1978 CB750F SUPERSPORT 850cc, cam, porting, dyna ign, cr29's lotsa elbow grease and $$'s. Worth ever penny!!  (S0ld)
05 VTX1800F darkside
cb750 k1
  • Dang IT!!!
« Reply #4 on: March 20, 2007, 02:43:52 pm »
Unfortunately I don't. What hole would you be referring too??
Cause I see 2 holes, but I don't know which hole is for the fluid to return.
 I will look at the plunger tonight and get back to you.
Thank you for all your help
My rides:
Past Rides:
  • go away winter!!!
« Reply #5 on: March 20, 2007, 03:45:54 pm »
Also make sure that both holes are clear. The smaller one is very tiny, I don't know if a paper clip wire will go thru it.
cb750 k1
« Reply #6 on: March 21, 2007, 09:03:41 am »
The problem is that with everything connected and the cylinder dry there is just too much air to move and it keeps compressing and expanding! When the master has starteed getting "wet" (for want of a better word) and moving fluid it will all eventually come out. All you are doing with my method is using your finger as a "Bleeder" and reducing the volume.
THE WARNING is cos brake fluid has been found to be one of the greatest causes of oil based dermatitis and if you work with spanners that just about finishes your career and yes i do know that for a fact only my cause was cleaning fluid in a parts washer!
  • go away winter!!!
« Reply #7 on: March 21, 2007, 06:12:07 pm »
Thats why I went with dot5  and cleaned all the parts of my brake system very well and went to stainless steel brake lines. Stops like a modern bike now!!! I have a good source for lines if anyone wants them.
cb750 k1
kettlesd
« Reply #8 on: March 22, 2007, 12:42:54 pm »
If the MC is OFF and in your hand then you should definitely have fluid if you squeeze the lever. Any chance your rubber piston cup is put on backwards???? Its not hard to have it happen actually when slipping it over the piston flange - or even to have it turn inside-out. The wider end of the cup shoudl face downstream toward the lines. If it is backward, it would have the effect of trying to draw fluid INTO the MC when you squeeze the lever instead of out of it.
Offline dpen
« Reply #9 on: March 23, 2007, 03:46:36 am »
Another way is to bleed the m/cyl itself first.
Fill with fluid & then pull the lever in slowly & gradually
When an air bubble pops from the hole in the bottom of the reservoir STOP, let sit for 30 seconds & pull lever in again
You'll get three or four air bubbles each time
DON'T PULL THE LEVER IN ALL THE WAY or you'll have to pull the cylinder apart to reseat the piston seal
This method takes about 20 minutes  ('till theres no air bubbles) & then you bleed as normal from the caliper(s)
I've used this for eons on bikes/trucks/cars etc etc
tmht
« Reply #10 on: March 23, 2007, 04:22:51 am »
You beat me to it Kettle. I just did this very same thing this week. Made me feel like a dumbass. Then it pissed me off because I had to deal with that stupid circlip all over again.  >:(
