After rebuilding my master cylinder on my 1981 CB650C, I find that the master cylinder won't push any fluid.
I use my vacuum gauge at the caliper and no fluid will drain down through the hoses. Then I try pumping the system, and I get no pressure.
I then take the master cylinder off and while it's in my hand I push down onto the brake lever and no fluid will even come out of the banjo opening.
Before I installed the K&L rebuild kit, the bore was completely smooth with no visible nicks at all.
The M/C is full of fluid and I was wondering if I need to have the top cap off when I'm priming the system??
Should some fluid come out into my hand when I squeeze the lever??
Right now I'm at a stand still. And the master cylinder is the dual caliper type. Could I have the wrong K&L kit??
Thank you
