Author Topic: Delkevic exhaust collector sealant  (Read 1111 times)
Offline Swoop
« on: July 13, 2024, 06:24:48 PM »
Just wondered if there was a consensus on what to use?
I’ve seen rtv silicone and anti seize mentioned. Getting a bit of carbon blow by when installed dry.
Thanks
Re: Delkevic exhaust collector sealant
« Reply #1 on: July 13, 2024, 08:39:10 PM »
Not rtv due to temp, antisieze doesnt make sense, exhaust pasteas used on cars would be best
Offline CycleRanger
  • No comment about being an
« Reply #2 on: July 13, 2024, 10:41:37 PM »
It doesn't use a graphite/carbon gasket?
« Reply #3 on: July 14, 2024, 02:40:29 AM »
I couldn't figure out "pasteas" I thought maybe it was a Brit thing.
Searched it, and found exhaust assembly paste. Then came back and re read it, I guess you must have missed a spacing, paste as. Sorry, it was confusing in morning fog brain at 0500.
Anyhow, I'm watching this as I have a Hindle system to mount up eventually that is also stainless steel.
Someone on a car racing forum said they use Coppaslip on their stainless steel exhaust system mounting as a lubricant/sealer. It helps to be able to move the pieces around in mounting to get the best fit in tight fitting pipes.
« Last Edit: July 14, 2024, 02:42:29 AM by newday777 »
« Reply #4 on: July 14, 2024, 05:28:32 AM »
No need to seal a Hindle 4-2-1.
Mine has a very tight fit.
Important to not tighten the exhaust spigots bolted to head (with stock crush seals) until the entire system is mounted.
Offline Kelly E
  • Geriatric Hooligan
« Reply #5 on: July 14, 2024, 08:27:48 AM »
We've installed 4 Delkevik exhaust systems and always use their red sealant paste with no leaks.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline Swoop
« Reply #6 on: July 14, 2024, 09:14:15 AM »
I probably would too….if it had come with it
« Reply #7 on: July 14, 2024, 09:35:53 AM »
I didnt miss a space its this damn dyslexic dumfone!!!
Offline Kelly E
« Reply #8 on: July 14, 2024, 12:02:51 PM »
All four of our systems came with a tube of it. They would probably send you a tube for free if you ask. They sent me a center stand stop for free, it didn't come in the KZ 1000LTD kit I bought.
« Last Edit: July 14, 2024, 12:05:01 PM by Kelly E »
1983 Honda CB 1100F
« Reply #9 on: July 14, 2024, 12:18:03 PM »
My fat finger edges usually do something dumb on me and I have to go through and fix a ting or t20......
Offline jaytee-nz
« Reply #10 on: July 14, 2024, 01:32:36 PM »
I think Delkevic have stopped supplying their red sealant as the last two systems I bought didn't have any in the box.
Offline Tim2005
« Reply #11 on: July 14, 2024, 02:05:49 PM »
For other stainless systems (I haven't tried a Delevik yet) I have used Permatex Ultra Copper sealant successfully for the collector joints, it seems to cope with the temperature very well.
https://gb.jbtools.com/permatex-81878-ultra-copper-maximum-temperature-rtv-silicone-gasket-maker/
Online beemerbum
« Reply #12 on: July 14, 2024, 03:44:46 PM »
No sealant in my Delkevic box. Nothing used. Never a leak at the collector or anywhere else
« Last Edit: July 14, 2024, 03:48:08 PM by beemerbum »
Offline denward17
« Reply #13 on: July 14, 2024, 03:48:36 PM »
I ordered a Delkevic 4into1 last September timeframe (for a 550) and the sealant WAS in the box.
Offline Kelly E
« Reply #14 on: July 14, 2024, 07:07:21 PM »
We bought a system for the 81' Suzuki GS 1100E two months ago and it had a tube of sealant.
1983 Honda CB 1100F
Offline Swoop
« Reply #15 on: July 15, 2024, 04:10:24 AM »
To all those that received the sealant, did it smell or look like it was silicone based? Did it dry hard or flexible?
Thanks
Offline denward17
« Reply #16 on: July 15, 2024, 06:16:22 AM »
Don't recall any smell but it did harden up.  It was difficult to remove after I took the pipes back apart, but some acetone helped.
Offline willbird
« Reply #17 on: July 15, 2024, 06:57:04 AM »
I bought one 6 mos or so ago and it came with it, I did not actually use it though.
