Author Topic: Seeking opinions on baking paint on cases?  (Read 1033 times)
Offline slyguy
« on: July 21, 2024, 05:03:05 PM »
I’ll be using the duplicolor de1615 spray paint & thinking of using our kitchen oven to bake once my wife is not around haha. Should I? If so, what temp & duration for each case halve? Tia👍
Re: Seeking opinions on baking paint on cases?
« Reply #1 on: July 21, 2024, 08:46:55 PM »
The engine itself does a pretty good job of cooking on that paint: I use it a lot. Use the engine Primer (in grey) underneath it. I use 2 lights coats of the primer, then one finishing (heavier coat) spaced 10-15 minutes between coats. Then before the first 1615 coat I wait 20 minutes. Then i use 2 thin coats of it with a heavier finishing coat, just like the primer. It will dry hard after 2-4 days (depending on humidity) so it handles pretty well.
« Reply #2 on: July 22, 2024, 01:34:00 AM »
Unless you want to buy your wife a new oven , then you better skip the idea of using the oven while she is gone. It will smell up the house for a long time and the oven will be giving an unhealthy flavor to everything that is baked in it for weeks if not longer...
Go price ovens and you will quickly rethink that strategy.
If you are heartset on baking it, with go find a used appliance shop or see if the local powder coats would consider baking it for you for a reasonable price...
« Reply #3 on: July 22, 2024, 03:43:20 AM »
I used a heat gun on my last case paint.
Rattle can, Motip engine paint, aluminium.
To speed up the process I used a heat gun after paint, blowing from inside until case became rather warm.
Offline BenelliSEI
  • 1969 cb750
« Reply #4 on: July 22, 2024, 09:03:10 AM »
I use the same paint all the time. It will bake nicely on first start up and drys hard enough to handle 3-4 days. Don’t stink up the house.
Offline slyguy
« Reply #5 on: July 22, 2024, 09:48:20 AM »
Ok guys, Super! I guess I’ll scrap the baking idea:)
« Reply #6 on: July 22, 2024, 08:44:13 PM »
 Baking during the run-in works unless the carbs leak all over and melt your new paint. A friend told me. Yeah, that's it a friend. It wasn't me, it was another big dummy.
Offline newday777
« Reply #7 on: July 23, 2024, 12:29:29 AM »
I seem to remember seeing a video of Allen Millyard's, using a gas barbecue grille to bake his cases outside to limit smell in the house (getting his wife into a tether, as she bakes him lots of muffins). You can usually find a used grille fairly cheap (to nothing)
VHT's recommended way on their high heat engine paint is bake at 200° for 20 minutes to get the protective properties.
Here's an old thread on baking cases from 2013
http://forums.sohc4.net/index.php?topic=120909.0
Stu
My current rides
Prior bikes....
Offline grcamna2
« Reply #8 on: July 23, 2024, 01:23:37 AM »
I sometimes use the VHT Caliper paint on parts that get hot or have mild contact with fuel,etc.
That VHT caliper paint is a durable product and they recommend 200 degrees for 1 hr.
I use the oven in my electric stove in my apt. as I live alone & don't use the oven to cook;I use a fan to pull air through the apt. from one window to the other when i do this.
Offline willbird
« Reply #9 on: July 23, 2024, 05:47:45 AM »
I honestly had thought about baking the engine myself. A couple bakes and solvent cleaning might get the last oily "stuff" out of any cracks and crevices too.
Bill
Offline slyguy
« Reply #10 on: July 23, 2024, 08:04:51 AM »
Thanks for everyone’s input;) I got them done…finally! The snail moves ahead lol
« Reply #11 on: July 23, 2024, 08:49:33 AM »
Allens wife does not bake muffins, she bakes cupcakes
Offline newday777
« Reply #12 on: July 23, 2024, 10:16:41 AM »
Stu
My current rides
Prior bikes....
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #13 on: July 23, 2024, 01:36:05 PM »
Rattle cans NEVER fully cure no matter how long or what temperature you get them to. They will be suseptible to dissolving/oxidizing 10 years out. They  harden via solvent evaporation not a chemical reaction.
You can put any 2K catalyzed clear over the Duplicolor and gas or any other solvent will not affect it.
« Last Edit: July 23, 2024, 01:40:16 PM by Ozzybud »
1976 Z50A YELLOW
1970 CT70 BLUE
1971 CT70H ORANGE
1972 CT70H GREEN
1973 CL200 BLUE
1973 CB350F RED
1975 CB360T RED
1975 CB400F BLUE
1975 CB550 ORANGE
1976 CB750F RED
Offline rotortiller
« Reply #14 on: July 23, 2024, 02:26:48 PM »
I do my best baking when home alone.
Offline Tracksnblades1
« Reply #15 on: July 23, 2024, 07:31:19 PM »
What Ozzy said ^^
Except I’d just have your dulicolor color duplicated in ImRon by your larger DuPont paint dealer and have them put it in a spray can.. Then it won’t matter if your carbs drip on it or not.. Around $50 - $75 bucks depending on color for the same stuff that’s on every Class 8 truck, boat, plane, and LP bottle from the manufacturer.  You’ll need your respirator and PPE…
Age Quod Agis
Offline grcamna2
« Reply #16 on: July 23, 2024, 07:39:47 PM »
Makes good sense.
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #17 on: July 23, 2024, 09:46:05 PM »
Duplicolor 1615 with PPG Omni clear coat.
1976 Z50A YELLOW
1970 CT70 BLUE
1971 CT70H ORANGE
1972 CT70H GREEN
1973 CL200 BLUE
1973 CB350F RED
1975 CB360T RED
1975 CB400F BLUE
1975 CB550 ORANGE
1976 CB750F RED
« Reply #18 on: July 24, 2024, 12:36:53 AM »
Duplicolor muffins now available in metallic
Offline grcamna2
« Reply #19 on: July 24, 2024, 07:58:38 AM »
Lol  ;D
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #20 on: July 24, 2024, 08:05:39 AM »
What Ozzy said ^^
Imron requires an activator(catalyst) and has an 8  hour pot life.
If it was put in a spray can you would have to use immediately or it would harden in the can!
Best $18.00 you will ever spend for small jobs!
« Last Edit: July 24, 2024, 08:13:10 AM by Ozzybud »
1976 Z50A YELLOW
1970 CT70 BLUE
1971 CT70H ORANGE
1972 CT70H GREEN
1973 CL200 BLUE
1973 CB350F RED
1975 CB360T RED
1975 CB400F BLUE
1975 CB550 ORANGE
1976 CB750F RED
« Reply #21 on: July 24, 2024, 10:09:16 PM »
What Ozzy said ^^
Yep, absolutely it’ll set up just like concrete.
And DuPont has it figure out, so you don’t have to reinvent the whee.
All you have to do is read the directions..
Age Quod Agis
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #22 on: July 25, 2024, 07:13:53 AM »
What Ozzy said ^^
Yes a 2K Rattle can would be a good option.
They mix the activator right before application.The big drawback is the entire can needs to be used right away and it's expensive
1976 Z50A YELLOW
1970 CT70 BLUE
1971 CT70H ORANGE
1972 CT70H GREEN
1973 CL200 BLUE
1973 CB350F RED
1975 CB360T RED
1975 CB400F BLUE
1975 CB550 ORANGE
1976 CB750F RED
Offline grcamna2
« Reply #23 on: July 25, 2024, 12:33:16 PM »
What Ozzy said ^^
+1 0n the 2K rattle can.
I painted my fuel tank on my Honda with Duplicolor black then coated it w/ 2K clear  ;)
