SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
CB750A - Hondamatic
(Moderators:
Sam Green Racing
raymond10078
Topic:
Dash Lights
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Dash Lights (Read 1501 times)
dubepj
Full Member
Dash Lights
on:
July 25, 2024, 03:10:14 PM »
Got the old girl running. Seems to have lots of power and runs Pretty good.
One issue is when I shift to Low the neutral light stays on and the Low light does not come on. ( bulb is good) When is shift to Drive the neutral light goes out and the Drive light come on as it should.
Where do I start looking.
Not sure gas gauge works accurately but that's about my biggest problems so far.
More concerned about the dash lights.
Logged
CycleRanger
No comment about being an
Really Old Timer ...
Central Texas Shop Manual Advocate
Re: Dash Lights
Reply #1 on:
July 25, 2024, 04:01:40 PM »
Not an A expert but the neutral switch might be stuck from sitting.
Check out the wiring diagram. I suspect the low light won't come on unless it sees the neutral switch off.
Logged
CB750K5 '79 XL250s CL350K3
CB750K3 '76 XS650 '76 CJ360T
dubepj
Full Member
Re: Dash Lights
Reply #2 on:
July 26, 2024, 08:16:21 AM »
I agree that the neutral switch might be stuck from sitting. How hard is it to access the switch. Shop manual doesn't really go into detail.
Logged
CycleRanger
Re: Dash Lights
Reply #3 on:
July 26, 2024, 09:07:45 AM »
I don't know if the A has a neutral switch in the same location as the other bikes. (under the engine)
There is also a "Change Switch" PN 35752-393-003 located near the shifter.
I assume this is for the hi/lo indicator.
I would examine the wiring diagram and the parts list for clues.
Logged
dubepj
Full Member
Re: Dash Lights
Reply #4 on:
July 28, 2024, 06:59:05 AM »
For me access the
Neutral switch
I think I have to remove side cover on left side. Also have to drain oil I'm guessing. Too bad, just changed it. Please tell me If I do this if I'll find that neutral switch??
Logged
CycleRanger
Re: Dash Lights
Reply #5 on:
July 28, 2024, 09:36:25 AM »
Don't know.
Do you have the shop manual?
http://manuals.sohc4.net/cb750a/
Looks like the neutral light goes through the "changing relay" where ever that is located.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
CB750A - Hondamatic
(Moderators:
Sam Green Racing
raymond10078
Topic:
Dash Lights
