Author Topic: 1975 CB750F Brake Rotors Alternatives Options  (Read 496 times)
Offline 4CM5
« on: July 28, 2024, 04:54:28 PM »
Hello everyone, asking for help on Brake Rotor (Front and Rear) replacement alternatives or resurfacing vendor.  OEM or NOS seem to be hard to find.  So, I started searching for aftermarket but, I’m not familiar with the quality or history of the brands, i.e., 4 into 1, Niche brands.
Asking if you have any recommendations; for a good source to purchase OEM/Aftermarket Rotors or a vendor for resurfacing.
Been doing a restoration on this bike, recently rebuilt the Master cylinders, front caliper and adding new SS Brake Lines soon (OEM lines still have 1975 stamped on them).
While I have the Wheels off, I’m considering removing the Brake Rotors, chain and chain sprocket for maintenance and/or replacement (if necessary). Although these are the original Rotors, they still have thickness between 6-6.5 mm, no warping or gouging (OEM Specs state 7mm Thickness with 296 mm Diameter – still within tolerance I believe).
Been searching the Forum for a couple weeks on Brake Rotors Topic, but can’t seem to nail down any specifics on 75-76 CB750F replacement options or a resurfacing vendor in the Los Angeles area.  Thanks in advance.
Andy…
From Los Angeles Area…
Offline newday777
Re: 1975 CB750F Brake Rotors Alternatives Options
« Reply #1 on: July 29, 2024, 06:11:17 AM »
Hey Andy
Godffery's Garage (Jeff is a member here) is set up to resurface the rotors and also will drill them(better braking)
Contact Jeff for pricing
https://godfferysgarage.com/
Stu
My current rides
Prior bikes....
« Reply #2 on: July 29, 2024, 06:13:25 AM »
EBC use to make an aftermarket rear rotor.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #3 on: July 29, 2024, 07:35:42 AM »
There are some iron rotors maybe still out there, they might work better but they don't look very good for very long.
Yamiya has rotors
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline 4CM5
« Reply #4 on: July 29, 2024, 08:21:56 AM »
Hey Andy
Great.  just looked at his website.  Good stuff/service i might use.  Thank you.
Offline 4CM5
« Reply #5 on: July 29, 2024, 08:22:53 AM »
Thank you.  I'll check out EBC.
Offline 4CM5
« Reply #6 on: July 29, 2024, 08:27:43 AM »
Yamiya has rotors
Thank you.  i'll look into Yamiya.
« Reply #7 on: July 29, 2024, 08:30:22 AM »
The front rotors are the same for all 750s except for the 1977-78 F2/F3.
Offline craz1
  • CDA, Idaho
« Reply #8 on: July 29, 2024, 08:47:44 AM »
Tom at TrueDisc. He does a great job
https://truedisk.net
74 CB550,73 Z1900, 74 Z1900, 75 Z1900,
72 XS2650, 73 RD350, 2013 FJR1300, 84 XJ550 YAM
Offline 4CM5
« Reply #9 on: July 29, 2024, 09:16:43 AM »
Got it, thank you. Hopefully my original rotors just need some fine grinding and cleaning.
Offline 4CM5
« Reply #10 on: July 29, 2024, 09:18:26 AM »
Thanks.  I found his website last night after making this post.  I’ll give him a call to discuss my options….
