Author Topic: K1 750 Gas Tank Trim  (Read 701 times)
Offline ZTatZAU
« on: August 04, 2024, 02:39:30 PM »
I'm still pondering my attack to modify my new set of Busso pipes and have decided to put off that phase of my K1 resurrection for last.
In the meantime, I would appreciate any tips or suggestions on...
1)  Finessing the curve of my NOS Honda badges to fit the curves of the tank.
2)  Installing the new badge pin nuts in the tank.
3)  Fitting the bottom aftermarket chrome trim strips.
I've never done this before and I'd like to get it right the first time without messing anything up.
Thanks!  ZT
Offline denward17
Re: K1 750 Gas Tank Trim
« Reply #1 on: August 04, 2024, 03:03:47 PM »
The push pins just "push" in, they will expand once you pop on the badges.
Is there a left/right side badge?  I think the ones on my 550 were, but not 100% sure.  I remember one side fit better than the other.
They just snapped on with side of my fist, popped on easily.
No experience with the bottom edge trim on a 750 tank.
Offline BenelliSEI
  • 1969 cb750
« Reply #2 on: August 04, 2024, 03:18:28 PM »
I push them in and them “massage” them with a soft white rubber mallet that I keep for just that purpose. Sounds odd, but really works. Where ever they seem to stand a bit proud, slide a piece of thin cardboard underneath and tap away.
Offline TideWater2
« Reply #3 on: August 04, 2024, 04:55:17 PM »
I used hot water instead of a heat gun for the bottom trim. I have a Keurig coffee maker in my garage, I ran a tall insulated tumbler full of hot water. Let the end set in the hot water a few minutes and started forming it to the tank. I just went back and forth from water to forming until I got it. Some good quality small plastic clamps helps hold the trim until it cools. The hot water gives much more control and even heating than a heat gun without the chance to burn it. The trim is less than perfect to start with, but its the best we got.
2 - 1971 CB750 K1s
Offline jwurbel
« Reply #4 on: August 04, 2024, 05:06:15 PM »
Be careful with the rubber hammer.  I have a friend who wasn’t paying enough attention and actually put a slight indentation in the tank.
Offline BenelliSEI
  • 1969 cb750
« Reply #5 on: August 04, 2024, 06:37:33 PM »
Wow. Like I said; “massage it”, don’t beat it to death!
Offline ZTatZAU
« Reply #6 on: August 13, 2024, 10:13:05 AM »
Thanks everyone!  I appreciate the replies and apologize for the unavoidable delay in getting back to you...
Thanks for the info Denward!  And yes, there is a left and right HONDA name badge... for the K1 750... 87121-300-030 (R) and 87122-300-030 (L).
Thanks John!
I really appreciate this TideWater2.  I got no instructions with the bottom trim pieces I received and had no idea there was any heat shrinking or gripping involved.  I was trying to figure how the little clips on the bottom of the tank are supposed to hold the trim.
Now that I've had a closer look at the trim pieces, it does look like another layer of "light colored something" folded into the crotch of the bend in the trim piece.  I thought this was some type of protective layer and even considered peeling it out.  I never would have guessed this to be a heat sensitive fastening method.  I'll keep your hot water suggestion in mind TideWater, but any additional info on fastening this trim would be much appreciated.
Massage it!  I got it, John!  I think the word I used up top was... finesse!
 :)  ZT
« Reply #7 on: August 17, 2024, 08:32:22 PM »
Where did you get the bottom edge trim?
Mine are in poor shape today. On these early bikes there are/were little flat sheet metal tabs (3 per side) that had to be bent downward to remove/install the chrome lip strip. It's always hard to get them bent back as flat as Honda originally had them! This often gets them broken off when someone removes the strips to paint the tank.
Online CycleRanger
  • No comment about being an
« Reply #8 on: August 17, 2024, 08:50:35 PM »
I bought tank trim from David Silver Spares a few years back.
They were pre-formed and fit nicely.
« Last Edit: August 19, 2024, 03:46:05 PM by CycleRanger »
« Reply #9 on: August 17, 2024, 10:46:04 PM »
  The hot water trick would have probably helped me deal with the ends which seemed pointy and required trimming.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #10 on: August 18, 2024, 07:48:07 AM »
I don't have any trim on my tank but I'm going to get it from Yamiya.
I have the metal tabs on the tank that hold it.
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #11 on: August 18, 2024, 09:54:54 AM »
I think I'm going to get some new, too. My poor steed hasn't seen any upgrades since 2013 when I rebuilt it!
Well, there is that new rear tire - I got one of those 'bad' Avons and it cracked all around 3 years ago, still had lots of tread, too. But, it's all dirty now. ;)
Offline BenelliSEI
  • 1969 cb750
« Reply #12 on: August 19, 2024, 11:34:54 AM »
The ones I get from Yamiya are shaped and easy to install. Warming them up sounds like a good idea!
« Reply #13 on: August 20, 2024, 07:49:40 AM »
On the tank badges, I carefully bent them by hand to the curve on the tank before instaaing, worked out just fine.
