Author Topic: Tach and Speedo Refresh Question  (Read 2547 times)
« on: August 22, 2024, 07:43:52 AM »
My cb750K1 has been much ignored lately. I have a spare, decent set of the correct speedo and tach for it. Planning to sub them in after a good refresh. Anyone ever use Randy’s Cycle Service? Other recommendations?
If someone on here wants to tackle them, I am in no rush and happy to wait!
I’ve done a few in the past and frankly was not impressed with my results. Curious what others do.
Re: Tach and Speedo Refresh Question
« Reply #1 on: August 22, 2024, 08:23:00 AM »
Offline The Lone Builder
  • "Still running against the wind"
    • Belfast-2-Belfast-By-Bike
« Reply #2 on: August 22, 2024, 11:10:22 AM »
I have done some also, John, and the issue is always removing/replacing the ring without damaging it.
Surely a a man of your abilities could come up with a way to do this successfully and share it with us mortals.
Meantime, I’ve use a guy in England called Peter Horton who does an excellent job and much cheaper than others I have seen.
He is on the UK site, Kent400: http://www.sohc.co.uk/index.php?action=profile;u=701
DO NOT confuse him with another English Peter - Bond - who is ….. not so good!
CB750 K2 - From Belfast-2-Belfast
CB750 K1 - The less, said the better!
CB450 K1 - Stalled.
CB400F Supersport - Not Rusty any more!
Follow my journey through Africa @ http://Belfast2BelfastByBike.com
« Reply #3 on: August 22, 2024, 11:32:29 AM »
Thanks Sean! Will check him out.
Offline leovich
« Reply #4 on: August 22, 2024, 01:29:59 PM »
The best speedo repair/refresh service I had was from TACHOWERK in Germany, he’s a real master and very kind guy. This is the website https://tachowerk.de/ and here you can reach Georg by email mail@tachowerk.de
I had a top quality service from him
« Reply #5 on: August 22, 2024, 02:10:47 PM »
Thankyou!
Offline TideWater2
« Reply #6 on: August 22, 2024, 06:44:08 PM »
I responded on the thread that Stev-o gave a link to earlier. I had sent a set of K1s to Classic Bike Meters, but I didn't post any follow up photos. I have sent a second set of K1s to CBMTRS that Patrick is working on now. The first set was a shade over $600. I did check Randy's and it looked similar in cost to CBMRTS, unless I missed something. I was very satisfied with the first set and wanted to stay consistent with the second set.
3 - 1971 CB750 K1s
« Reply #7 on: August 22, 2024, 07:06:45 PM »
Another option. Thanks!
Offline Oddjob
« Reply #8 on: August 23, 2024, 04:01:58 AM »
There is a member on the UK forum called Peter Horton (Kent400)who is the go to guy for all the other members to get their clocks done by him. He charges very reasonable rates, $600 is an obscene amount to pay.
Peter did a set of CB550F2 clocks for me, fitted newly rezinced bottoms, the dishes were resprayed satin black and the needle damper reservoir was refilled. I can't remember what I was charged but it wasn't anywhere near $600, the clocks looked as good as new afterwards. Plenty of pictures of Peters work on the UK forum. As in https://www.sohc.co.uk/index.php/topic,27365.msg254007.html#msg254007
Found the cost, less than $100 for both gauges, that was a couple of years ago now but it should still be in the ballpark so to speak. I hope Peter doesn't mind me recommending him for work, I do know he's very busy at times though.
Also found some pics. Peter had to replace my dish on the tacho and the only one he could find had a very small dent in the edge near the glass, as I'm fitting chrome covers over these it wasn't a problem.
« Last Edit: August 23, 2024, 05:46:23 AM by Oddjob »
« Reply #9 on: August 23, 2024, 04:43:11 AM »
Thanks again! I think this might be the same fellow Sean mentioned. Lots of options and I will be checking then out!
Offline jwurbel
« Reply #10 on: August 23, 2024, 05:37:29 AM »
I used Randy Creel.  Was more than pleased.  Price was $550.  I had looked at doing it myself with aftermarket faces but didn’t have the confidence that I wouldn’t destroy the backing. The cases themselves are also refinished.
« Reply #11 on: August 23, 2024, 02:34:27 PM »
Where is he? How do I find him?
Offline jwurbel
« Reply #12 on: August 23, 2024, 06:35:55 PM »
recycle.com should work
« Reply #13 on: August 23, 2024, 07:33:22 PM »
« Reply #14 on: August 24, 2024, 05:10:04 AM »
Hmmmm. Don't think so......
« Reply #15 on: August 24, 2024, 07:42:39 AM »
Too bad CB750 Faces no longer does this. I guess Marcel wanted to slow down or change lines of work.
Offline Oddjob
« Reply #16 on: August 24, 2024, 08:58:59 AM »
Got to be honest and say that Peter Hortons work surpasses Marcels in my opinion. He’s done loads of 750K0 gauges and every single owner has raved about the quality. He even has a machine to disband and reband the gauge without damaging the band. He’s also the cheapest one around as far as I know.
« Reply #17 on: August 24, 2024, 10:05:06 AM »
Following  ;)
Offline jwurbel
« Reply #18 on: August 24, 2024, 11:18:48 AM »
rcycle.com is correct for Randy Creel.  Spell check sucks!
« Reply #19 on: August 24, 2024, 02:16:16 PM »
Marcel still selling the parts for the work but his work was cosmetic, so no repairs. I do not include refills of the damper pot as a repair.  Given the cost of the parts it sounds like Peter Horton is by far a better turn key solution. The shipping to him will probably be greater than his return shipping costs. You might have better luck in Canada with shipping costs to GB than we do in the US as all options I am aware of are fairly costly for a package of any size and weight.
Offline jonda500
« Reply #20 on: August 24, 2024, 08:35:59 PM »
That wouldn't be hard - I can't find anything positive to say about Marcels work - he left me feeling completely ripped off!
I am glad to see some other options available if I can re-save up the money to try again!
John
A starter clutch thread:
Offline leovich
« Reply #21 on: August 26, 2024, 11:47:49 AM »
I had a bad experience with Marcel. The first time I sent him my K0 gauges, I had them back after a year, I was not able to speak at him and he replied to my mails with a long delay. He was good only for the face plates that he produce, but as other had said, he only worked on cosmetic restoration.
After my gauges came back from him the Speedo was showing 15-20 km/h less than real speed and the trip counter worked bad so I had to ship again to be repaired but the second time I sent to TACHOWERK in Germany. He repaired even the internal speedo mechanism and finally I was able to ride with pleasure
Offline MLW9110
« Reply #22 on: August 26, 2024, 02:38:48 PM »
I recently disassembled, cleaned and lubricated my 1977 CB550F speedo and tach myself. Both instruments weren’t working right. I made a cut in the bezel ring with a Dremel tool. I cleaned the mechanisms with Deoxit spray and used clock oil to lube the moving parts.
I used clear sealant on the inside of the bezel rings and used a big hose clamp to hold them in place until the sealant cured.
Both instruments are working great now.
« Reply #23 on: August 27, 2024, 07:07:46 AM »
I had an issue with my gauges that he restored, had to ship them back at my cost [$60]. But he did take care of it.
Offline jonda500
« Reply #24 on: August 27, 2024, 07:08:07 PM »
I shipped mine back to him twice at great expense - he did NOT take care of it, actually made them worse and 2nd time he shipped them back with no odometer trip meter reset knob installed!!  >:(
John
