Thanks all... Apex Brakes it is!
I'm in the process of setting up the hoses to photograph with dimensions like John has described, but I do have a few more questions.
Upper Hose (#45126-300-0020): As you can see above, the hose I have has been modified by PO with a 3 inch extension. Not including the extension, that hose measures 20.75 inches in length. Looking at suppliers that have these for sale, they state they are 15.5 inches in length. I have no other CB750 upper hoses to compare it to, so could someone please confirm the actual length you have ordered for your K1's. Also, I see on the Apex Brake site they talk about the "Type of Angle" each end fitting is oriented to each other, so if there is an angle associated with this hoses fittings could someone identify that too? (FYI, my bike has stock handle bars).
Lower Hose (#45125-300-010): The hose I have measures 14 inches. It has the 10mm straight banjo fitting at one end, but I'm looking at the Female end fitting and am wondering which of the ones described on the Apex it is? (from what John says it sounds like Raymond will know which ones it is so more for my own knowledge)
I take it everyone gets new #90145-300-000 bolts and #90545-300-000 washers for these. Any suggestions on the best place to procure them would also be appreciated.
