Author Topic: CB750K1 Oil Pan  (Read 427 times)
Offline pjandrew99
CB750K1 Oil Pan
« on: September 10, 2024, 04:49:45 AM »
Replaced a cracked oil pan with one on Ebay. Took a bad leak to a minor leak but a leak just the same. The pan was replaced with a similar pan. These pans both have a triangular tab next to the drain plug. The tab seems to hit up against the engine block and have no particular purpose. Part number shows 11210300050(tab) for motors after 1007414. Mine is 1107769.
Motors before that use 11210300040. No tab on those.
Seems to me that tab could cause the pan to crack as its tighten against the block.
I priced the earlier pans and its about 3 times the price.
Hesitant to tighten anymore in fear of cracking this pan. Using a gasket with no Hondabond or other sealant.
Could use some direction. Thanks!
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
Offline BenelliSEI
  • 1969 cb750
Re: CB750K1 Oil Pan
« Reply #1 on: September 10, 2024, 05:12:12 AM »
The “fin” is a retainer for what’s above. I always use a small amount of gasket cement on both side of that gasket……
Offline pjandrew99
Re: CB750K1 Oil Pan
« Reply #2 on: September 10, 2024, 05:26:11 AM »
Thanks!
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
Offline Kevin D
  • SE Michigan
Re: CB750K1 Oil Pan
« Reply #3 on: September 10, 2024, 06:28:14 AM »
The drain bolt boss isn’t particularly strong. Make sure you have a decent crush washer and don’t reef on the drain bolt. It’s a candidate for torque wrench use IMHO.
Not too tight, certainly
Not too loose, certainly.
I busted one in my youth, the weld repair didn’t take.
The round plug, I believe, is to facilitate shift fork placement during engine assembly. I have never seen one out, theres no oring sized for it that I’m aware of.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
