Author Topic: 78 750F PD 42A Carb question  (Read 754 times)
Offline majorzozo
« on: September 13, 2024, 12:02:18 PM »
Hi all,
I have PD42A carbs on my 78750F.  Carbs 2 and 3 have flat type O rings where the throttle shaft passes through the carbs (4 each) and carbs 1 and 4 have felt (2 each).  The choke shaft has all felt (6 each)  I cannot seem to find a part number anywhere or any information on the flat type O rings as mine are shot.  Does anybody know where I might obtain these?  Should I just replace these with the felt type?
Any information is appreciated and thanks in advance..
Re: 78 750F PD 42A Carb question
« Reply #1 on: September 13, 2024, 12:22:37 PM »
There never was a pqrt number for any of those parts, they only came with the bodies
Offline newday777
« Reply #2 on: September 13, 2024, 02:18:30 PM »
They should be felt. Not available from Honda.
There are some sizes on ebay.
Check the diameter of yours.
Stu
My current rides
Prior bikes....
Offline majorzozo
« Reply #3 on: September 14, 2024, 05:08:09 AM »
Thanks.  I wasnt sure if you could replace the rubber O rings on 2 and 3 with felt.  Any idea why those 4 would be different?
« Reply #4 on: September 14, 2024, 05:25:25 AM »
Somebody has been in there before and couldnt get felt
