Author Topic: Oh dear ...  (Read 1270 times)
Online 69cb750
Oh dear ...
« on: September 16, 2024, 06:59:15 AM »
When you think you have seen everything ... you have not.
Re: Oh dear ...
« Reply #1 on: September 16, 2024, 07:57:59 AM »
I would never say that!!!   Oil tank, right?
Re: Oh dear ...
« Reply #2 on: September 16, 2024, 08:07:26 AM »
JB Weld will fix that ;D ;D
  • I'm back
Re: Oh dear ...
« Reply #3 on: September 17, 2024, 12:22:14 AM »
Would any of you be so kind to explain what this JB Weld stuff is (pics?)? It has been mentioned in this forum many times and I still know what it is, consists of and if there possibly is a variety of JB Weld products (like Loctite has various products). I'm convident there is a European equivalent, but as of now, I don't know where to start looking. Appreciated.
Offline jaytee-nz
Re: Oh dear ...
« Reply #4 on: September 17, 2024, 12:25:55 AM »
Delta - check these out. It's sold in New Zealand so it must be available in Holland !
https://www.jbweld.com/products
Offline robvangulik
  • Honda Fourever
Re: Oh dear ...
« Reply #5 on: September 17, 2024, 01:52:29 AM »
I haven't seen it here either, but it is a plastic metal, I have used Weicon plastic metal several times.(vloeibaar staal )
Offline pjlogue
Re: Oh dear ...
« Reply #6 on: September 17, 2024, 02:45:47 AM »
It is a two part epoxy.  the base has metal powder and it is mixed 1:1 with a cream colored hardener.  Once cured it is impervious to any solvents that I know of.  It is very strong and will adhere to just about anything other than flexible plastics.  it can be machined, drilled and tapped.  I have used it to fill  in rust divots in anti-sway bars on cars, repair stripped out threads in engines and fill in missing chunks of metal parts.  Very versatile product!  The only thing I would not use it for is a high heat application.
-P.
Offline Oddjob
Re: Oh dear ...
« Reply #7 on: September 17, 2024, 03:16:06 AM »
There is a high heat version pjlogue. I've got some somewhere.
Re: Oh dear ...
« Reply #8 on: September 17, 2024, 03:21:07 AM »
We had mostly this before.  Harden in 10-15 minutes.
https://www.tridentuk.com/gb/product-plastic-padding-chemical-metal-210g-md171297.html
I repaired a leaking alternator cover to my K6 with it. The cover had said hello to the asphalt several times.  Leaned bike to a wall, cleaned with acetone and epoxy on.
Used the bike 20 minutes later. I had this stuff in the luggage on longer tours.
Standard JB Weld epoxy need longer time to harden but is better. It is thinner and is rinny before hardening.
Our importer mentioned shelf life of 25 years...
Offline jlh3rd
Re: Oh dear ...
« Reply #9 on: September 17, 2024, 04:24:35 AM »
this is the original JB weld that gets the highest ratings compared to even other jb weld products
« Last Edit: September 17, 2024, 05:07:26 AM by jlh3rd »
Offline jlh3rd
Re: Oh dear ...
« Reply #10 on: September 17, 2024, 04:35:30 AM »
since that is a rusted area you might want to take a look at POR-15 products made specifically to adhere to rusted metal. They make a crack sealer and a 2 part putty.
FWIW, the original JB weld tested stronger than the POR 15 putty but how well does jb weld stick to rusted metal?
Offline rotortiller
Re: Oh dear ...
« Reply #11 on: September 17, 2024, 04:49:24 AM »
If it were me I would braze or weld in a patch seeing that it is steel. JB Weld has its place but that is not one of them. Generally it is used as a cheap low skill repair often plastered over broken aluminum castings. Since you have access to the tank by removing it, it can be cleaned  and welded or easily replaced with a junked item. JB Weld is not structural, more like epoxy body filler. The fitting for the oil line looks weak, a correct patch can correct that.
Online 69cb750
Re: Oh dear ...
« Reply #12 on: September 17, 2024, 05:53:05 AM »
Yes
Will get patch from 71 tank, weld on 69 tank.
Offline The Lone Builder
  • "Still running against the wind"
    • Belfast-2-Belfast-By-Bike
Re: Oh dear ...
« Reply #13 on: September 17, 2024, 06:26:59 AM »
Look here: https://www.amazon.nl/s?k=JB+weld&ref=nav_bb_sb
CB750 K2 - From Belfast-2-Belfast
CB750 K1 - The less, said the better!
CB450 K1 - Stalled.
CB400F Supersport - Not Rusty any more!
Follow my journey through Africa @ http://Belfast2BelfastByBike.com
Online 69cb750
Re: Oh dear ...
« Reply #14 on: September 17, 2024, 06:35:58 AM »
I continue to be surprised by things I find on old bikes.
   Oil tank, right?
Yes
Re: Oh dear ...
« Reply #15 on: September 17, 2024, 07:25:39 AM »
I think the nearest to JB would be Araldite in europe, for plastic metal in various metals Devcon but that is pricey, used a lot of that as sea in merchant navy
Online 69cb750
Re: Oh dear ...
« Reply #16 on: September 17, 2024, 08:03:24 AM »
The rest of the story ...
I was testing the bike.
Ride up and down my street, everything ok.
Ride out Ravine road to D ave and home, 14 miles, everything ok.
2nd trip out to D ave oil light comes on, I stop, oil on tire, wheel, dripping off exhaust pipes.
Get tool kit out, try to tighten return line nut, nut already tight.
A very nice man 25 to 30 years old stops and asks if he can help.
Yes, two quarts of oil please, he returns with oil, refused to take any money.
7 miles home, lost 1.8 quarts of oil.
Next day removed tank and found rust, poked through rust with screw driver.
Tank held oil 14 miles then hot oil broke through rust.
I have had several roadside adventures through the years, first time for this problem.
Re: Oh dear ...
« Reply #17 on: September 17, 2024, 08:06:35 AM »
Sweden has an importer that has the JB Weld products.
https://navx.store/product-category/jb-weld/
JB Weld product portfolio seems to grow at every visit.
https://www.jbweld.com/product/j-b-weld-tankweld
I should also find a welder that could fix it properly.
« Last Edit: September 17, 2024, 08:35:34 AM by PeWe »
Re: Oh dear ...
« Reply #18 on: September 17, 2024, 08:32:12 AM »
  Often the JB weld option is a real suggestion, other times it is offered as sarcasm. The trick is to know which time it is now.
  If you lived down the street, I'd bring a tank over for you to keep. Shipping that far might not make sense.
Re: Oh dear ...
« Reply #19 on: September 18, 2024, 08:11:32 AM »
Not sure I understand, is this about the square four bike??
Online 69cb750
Re: Oh dear ...
« Reply #20 on: September 18, 2024, 10:07:13 AM »
No, was testing 69 CB750 when oil tank failed.
Making progress on protype, posted clutch photo today, not ready for road testing.
« Last Edit: September 18, 2024, 10:09:00 AM by 69cb750 »
Re: Oh dear ...
« Reply #21 on: September 19, 2024, 07:28:59 AM »
Got it.  The oil tank failure and the pic of the rusted oil tank confused me.
Re: Oh dear ...
« Reply #22 on: September 19, 2024, 07:39:09 AM »
I would be concerned about how much rust is on the inside and can't be repaired without welding in a new patch on the bottom.
