Author Topic: Hydraulic clutch conversion for the mono shock dragbike. Will it work??  (Read 6343 times)
Offline dragracer
  • CB750F Dragbike
Re: Hydraulic clutch conversion for the mono shock dragbike. Will it work??
« Reply #50 on: October 10, 2024, 09:13:44 PM »
I wonder if the smaller slave cylinder would work great with an adjustable ratio clutch master cylinder. The small bore can create a lot of pressure. I do have one of these I traded for port work years ago.... https://apracing.com/special-vehicles/motorcycle/master-cylinders/pull-type-adjustable-ratio-master-cylinders/variable-ratio-type-cp4125-26.  I ordered that small slave.....we'll see.
Only one sure way to find out.  I'm glad you've got that master cylinder on hand Mike. Between the two of us maybe we can come up with something that works in all applications,  from everyday street riding to full out dragracing. Nothing ventured,  nothing gained.
