Author Topic: Thoughts on Oil  (Read 1627 times)
Offline Hospitaller
Thoughts on Oil
« on: September 20, 2024, 01:52:27 PM »
I know the consensus seems to be that 20w50 is the best for my k4 for longevity.  I was gifted a case of Honda GN4 in 10w40 which is what the book calls for.  It shouldn't hurt my girl to use this oil up and then go back to 20w50, should it?  I figure I have way bigger problems currently since I need new cables and resistors, points, a transistorized ignition, plugs, coils, to get the keyster metering rods out of my carbs because even at 4600ft the plugs are ever so slightly too white, on and on. Oh yeah, and swing arm bushings... it never ends does it?
Diplomacy is the art of saying 'Nice doggie' until you can find a rock. -Will Rogers
1974 CB750K4
Re: Thoughts on Oil
« Reply #1 on: September 20, 2024, 02:51:33 PM »
What resistors, non i know of on 750
Re: Thoughts on Oil
« Reply #2 on: September 20, 2024, 03:10:00 PM »
What bike are you on?
What is the temperature outside 🤔???
Re: Thoughts on Oil
« Reply #3 on: September 20, 2024, 04:00:36 PM »
You can check your spark plug plug wire caps to see if they need replaced.  But new ones are pretty 😁
« Last Edit: September 20, 2024, 04:02:36 PM by Tracksnblades1 »
Re: Thoughts on Oil
« Reply #4 on: September 20, 2024, 06:46:29 PM »
Darn...I thought this was an oil thread.
Re: Thoughts on Oil
« Reply #5 on: September 21, 2024, 12:09:54 AM »
Please no!!!
Re: Thoughts on Oil
« Reply #6 on: September 21, 2024, 02:40:52 AM »
you see its like this,an oily resistor is more slippery.
Re: Thoughts on Oil
« Reply #7 on: September 21, 2024, 03:34:56 AM »
Dave, i know people say it aint possible but you really do get worse mate!!!
Re: Thoughts on Oil
« Reply #8 on: September 21, 2024, 04:56:58 AM »
im glad you called me mate!
Re: Thoughts on Oil
« Reply #9 on: September 21, 2024, 05:28:13 AM »
We are too bloody similar not to Dave, both creakey and drivers for a start!
Re: Thoughts on Oil
« Reply #10 on: September 21, 2024, 02:36:21 PM »
Use it up. Good stuff.
Offline CB750R
  • 77 CB750F
Re: Thoughts on Oil
« Reply #11 on: September 23, 2024, 06:33:42 AM »
Use it in spring or fall, use the 20w50 in the summer!!
Offline willbird
Re: Thoughts on Oil
« Reply #12 on: September 23, 2024, 08:36:07 AM »
If we looked at the "body of work" of the lifetimes of all of our bikes combined I'd bet a cold soda that 10w40 oil was used more than anything else.
That does not mean it is "optimum" of course.
Bill
Re: Thoughts on Oil
« Reply #13 on: September 23, 2024, 09:07:22 AM »
Ok, I'm gonna type it, any oil will work!  But some better than others, I just wont use synthetic for clutch reasons.
Re: Thoughts on Oil
« Reply #14 on: September 23, 2024, 11:14:58 AM »
FWIM  I’ve always used 20w-50 Vavoline it has excellent high temp load carrying capacity..not the best but not the worst. However now that Vavoline offers motorcycle 4stroke oil, the conventional 20w-50 is no longer recommended for wet clutch operation….
Just for a FYI. Since 2007, Honda’s motorcycle manuals calls for 10w-30 instead of the forever 10w-40 recommendations.
If you look at the crankshaft clearances of Honda’s modern air cooled engines compared to these old SOHC’s clearances, you’ll see nothing has changed, clearances wise..
Re: Thoughts on Oil
« Reply #15 on: September 23, 2024, 11:22:22 AM »
True, but their modern oil pumps deliver almost 2x as much oil flow, too! :)
In the older cars we learned that we could drive them way over 100k miles if we switched to 'hi output' oil pumps, which were available for almost every Detroit engine made. I did it with several of my Ford engines and they rolled over 200k (and one over 460k) miles with ease.
« Last Edit: September 23, 2024, 11:24:42 AM by HondaMan »
Offline jonda500
Re: Thoughts on Oil
« Reply #16 on: September 23, 2024, 05:41:54 PM »
Bill
+1
I used 10w40 diesel oil in my CB450 for ten years with no problems! John
A starter clutch thread:
Offline beemerbum
Re: Thoughts on Oil
« Reply #17 on: September 24, 2024, 03:08:55 PM »
Read somewhere that a high zinc content is good for M/C oil. If so, why?
Online Don R
Re: Thoughts on Oil
« Reply #18 on: September 24, 2024, 04:53:09 PM »
 Zinc smears itself into high pressure contact points and keeps the parent metals from rubbing directly on each other. HA! Here we go! I'm likely wrong and don't care, flame away!
Re: Thoughts on Oil
« Reply #19 on: September 24, 2024, 06:35:10 PM »
Bullseye!
:D
Offline willbird
Re: Thoughts on Oil
« Reply #20 on: September 25, 2024, 08:18:36 AM »
The "motor oil geek" Lake Speed Jr has a lot of youtube videos on engine oil chemistry, worth looking him up and giving them a view.
Offline Hospitaller
Re: Thoughts on Oil
« Reply #21 on: September 25, 2024, 09:13:50 AM »
The spark plug caps, Mine could be factory.  I measured them a while ago and they were pretty much out of spec. The ones I could get to, someone glued the cables into most of them.
750K4, 90F now, in three months 20F or below.  I still ride if the roads are clear and dry. It doesn't snow that much in the Salt Lake Valley in Northern UT it is just doggone cold.
Truth, and being an Automotive Tech/Hot Rod builder, I'm always in favor of more oil flow.  Is that an option for this engine? You will probably see it in the next couple of years anyway to fix core shift and possible blueprinting/streetable mods(new rocker shafts, light port work, clutch oiling mods etc.) I just want to take the best care of her I can until then.
1974 CB750K4
Offline Swoop
Re: Thoughts on Oil
« Reply #22 on: September 25, 2024, 09:21:57 AM »
I think he’s talking about them there resistors that capacitate
Re: Thoughts on Oil
« Reply #23 on: September 26, 2024, 12:23:39 AM »
For my 48 year old engine the most important characteristic of an oil is, it will be nice for the rubbers. I have best results with Castrol GTX 15W-40, aka High Mileage. It even cured the shifter seal and so the new one is still in its plastic bag. There are more rubber parts inside our engines than people think...
Offline rotortiller
Re: Thoughts on Oil
« Reply #24 on: September 26, 2024, 06:20:20 AM »
Oil is like beer, you have the taste and you have the alcohol content. I tend to pick a major brand, change it often enough, stick with it, and select the 10W40 general oil weight spec'd by Honda, Suzuki, etc of that era. I like to go by decades on the planet, a 45+ year old bike (s) with tens of thousands of klicks, and a slew of empty oil cans to form my opinion.  Lots of stuff is invented concerning our secret sauce, kind of like tainted versions of history lol. Taken to extremes an incorrect beer choice can cause the runs, but also very important is to remember that oil is like beer in another very important way, you only rent it for a short period of time.
