Author Topic: Installing a Sidestand Spring.  (Read 2100 times)
Offline BenelliSEI
  • 1969 cb750
« on: September 20, 2024, 02:07:42 PM »
I discovered a great way to reinstall the spring, a while back (wear safety glasses and gloves for this stunt). Swing the side stand in the down position and hook the spring at the frame end. Take a large Phillips screwdriver and line up one of the tip grooves under the hook on the stand. Loop the spring on the shaft of the screwdriver. Using both hands, push straight down on the handle of the screw driver. Everything gets really tight but as soon as the shaft gets below the hook, the spring shoots up the screwdriver shank and snaps into place. Takes some practice, but works well.
« Last Edit: September 20, 2024, 02:09:19 PM by BenelliSEI »
Offline Kelly E
  • Geriatric Hooligan
Re: Installing a Sidestand Spring.
« Reply #1 on: September 20, 2024, 02:41:32 PM »
I use a drum brake spring installation tool for that job. Works like the screwdriver but there's a notch in the end to catch the spring mounting peg.
« Last Edit: September 20, 2024, 02:53:25 PM by Kelly E »
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline CycleRanger
  • No comment about being an
« Reply #2 on: September 20, 2024, 04:31:51 PM »
Yep, best method if you have one. I've done the screwdriver thing too.
« Reply #3 on: September 20, 2024, 06:43:14 PM »
I use pennies.
Or sometimes, quarters.
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #4 on: September 20, 2024, 06:45:26 PM »
I use my fingers
« Reply #5 on: September 20, 2024, 08:32:31 PM »
I posted about using the brake tool last week on Benelli's cool tools thread. ::)
http://forums.sohc4.net/index.php?topic=191752.350
« Reply #6 on: September 20, 2024, 08:54:06 PM »
When the side-stand is in the up position, the spring isn't stretched as far as when in the down position, so it's easier to install the spring.
Another trick, if you don't have the brake tool (or even if you do) is to hook both ends of the spring with the side-stand pivot bolt removed, and then lever the stand into position and fit the bolt.
« Reply #7 on: September 21, 2024, 09:38:45 AM »
I've done that one 750K4 recently, to avoid having to remove the pipes on a custom-piped 750. It took a very thin, long screwdriver to get past those shiny pipes! His sidestand had spread outward at the upper pivot (top plate bent out) and the bike would lay over so far on the sidestand that it could fall over if parked on a slope(!). It needed a new sidestand.
It's really spooky working around someone else's custom chrome...
Offline Kelly E
« Reply #8 on: September 21, 2024, 05:42:05 PM »
I hear you about working on other people's stuff. I was a bit nervous working on my buddy's 64' Norton Atlas 750. Especially since I had never ridden one let alone work on one. It was a learning experience for sure. 8)
1983 Honda CB 1100F
« Reply #9 on: September 21, 2024, 06:41:50 PM »
Those were popular street racers on Saturday nights when I was a kid: them, and the Bonnevilles would always go after each other, zooom!
Offline carnivorous chicken
« Reply #10 on: September 21, 2024, 08:10:00 PM »
I use my teeth.
Offline Kelly E
« Reply #11 on: September 22, 2024, 10:18:29 AM »
I use my teeth.
How many teeth do you have left? ;D
1983 Honda CB 1100F
« Reply #12 on: September 22, 2024, 02:50:33 PM »
I use my teeth.
All including my wisdoms! They're stronger than dirt!
