Author Topic: Cleaning SL350 K0 Black Carbs  (Read 1930 times)
Offline pjandrew99
« on: September 23, 2024, 02:47:22 AM »
Usually, clean carbs in ultrasonic cleaner with a water/simple purple mix. Worried that it will remove the paint and wondering what would be safe to use.
Also, if I go the ultrasonic cleaner route, do I need to punch out the emulsion tubes or can I leave them in. So far, the carbs have been pretty clean aside from some sediment in the bowl. Thanks!
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
Re: Cleaning SL350 K0 Black Carbs
« Reply #1 on: September 23, 2024, 04:13:36 AM »
The carbs didn't come black from the factory.
Paint will come off in the ultrasonic/heat or carb dip soak cleaner. Even spray cleaner on the paint will strip the paint.
Offline pjandrew99
« Reply #2 on: September 24, 2024, 05:47:40 AM »
Thanks!
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
« Reply #3 on: September 26, 2024, 07:57:30 PM »
They will also work a lot better when they aren't coated in paint. ;)
Look for tiny plugged-up vent holes, I think the first SL350 (with the CV carbs) had 1 on the inside of each carb body.
Offline pjandrew99
« Reply #4 on: September 27, 2024, 05:59:06 AM »
Thanks!
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
Offline CycleRanger
  • No comment about being an
« Reply #5 on: October 19, 2024, 05:15:11 PM »
Actually I believe the SL350K0 did come from the factory with black carbs. But it was just paint.
Offline pjandrew99
« Reply #6 on: October 20, 2024, 01:50:32 AM »
Did a bit more research and yes they did come in black that year. I did run them through the ultrasonic cleaner with a bit of LPS Precision cleaner. Paint stayed on fine but took a bit of sheen off the finish.
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
