Author Topic: 1978 cb750k- and so it begins  (Read 22444 times)
Offline Alan F.
Re: 1978 cb750k- and so it begins
« Reply #100 on: July 16, 2025, 12:35:37 PM »
 No Kawasaki to Honda conversion bearings? I'd have never guessed that. What a sh!tty situation they put you in, they really should accept your return since they should have a recording of your original call preceeding your order.
Maybe roll a sleeve from cold rolled steel?
Offline Dime
« Reply #101 on: July 16, 2025, 01:08:32 PM »
Ya it is a crappy situation for sure. I have the other bearings ordered. Once they get here I will do final measurements and install races. Then I will have a machine shop make the sleeve, install it on the stem and go from there.
All balls have lots of conversion bearings for other Kawasaki's but not the one I am using apparently.
Offline Dime
« Reply #102 on: July 17, 2025, 07:33:15 AM »
New bearings are ordered. Have the local all balls dealer I got on of the bearings off of checking to see if they can get me the dust sheild and spacer separately that way I can keep the kit intact and hopefully resell it.
I have an email into the company in the UK I got the second bearing from, which was the more expensive of the two to see if I can do a return.
I have been talking to a machinist about doing the pressed sleeve for me and he said it is no problem so that is a win. Just have to wait for the bearings to show up before I can go ahead with that part.
If neither of the companies don't accept returns I don't blame them. It was not their fault.  Lesson learned, trust but verify.
Sent from my SM-S721W using Tapatalk
Offline Dime
« Reply #103 on: August 01, 2025, 12:11:53 PM »
New neck bearings are in. Bottom race installed perfectly, haven't done the top yet.
Had to modify the all balls dust seal. Had to remove the lip on the outer edge to get it to sit where it needed to in the neck.
All is well now and I am off to the machinist on Monday to have the sleeve machined for the stem.
Offline Dime
« Reply #104 on: August 05, 2025, 06:20:19 AM »
The machinist took care of the sleeve for the neck stem no problem.
Could not resist doing a full mock up to get an idea of the overall stance. I am really digging it.
Offline Alan F.
« Reply #105 on: August 05, 2025, 06:24:38 AM »
That does look good, congrats on good progress.
Offline Dime
« Reply #106 on: August 05, 2025, 06:36:51 AM »
Thank you. It has been a slow grind but am finally coming along
Offline denward17
« Reply #107 on: August 05, 2025, 06:48:30 AM »
I like that front end, is it stock rake?
Offline Dime
« Reply #108 on: August 05, 2025, 07:00:02 AM »
Yes it is stock rake. The front end and wheels are off a 1981 kz1000 ltd.
The kz front end is 4" longer than the stock cb750k front end. Plus the kz front wheel is a 19" vs the stock 18" of the cb750k.
Online newday777
« Reply #109 on: August 05, 2025, 07:52:29 AM »
The CB750 front wheel is 19" (69-78), the back wheel on a 77/78K is 17"(69-76 is 18")
« Last Edit: August 05, 2025, 07:55:25 AM by newday777 »
Offline Dime
« Reply #110 on: August 05, 2025, 07:55:48 AM »
The CB750 front wheel is 19" (69-78), the back wheel on a 77/78 is 17"(69-76 is 18")
I could of sworn that it had a 18" up front. My bad.
Offline Dime
« Reply #111 on: August 10, 2025, 09:04:10 AM »
Just ordered this for the scoot. Has high and low beam. 4200k. Should work out nicely. Will have to fab a bracket to mount it but I have it in my head how it will go so should be pretty straightforward.
Offline Dime
« Reply #112 on: August 13, 2025, 03:34:59 AM »
I traded my bender for the kz1000 LTD parts I am using on my cb750 sohc. I contacted the guy and he wasn't using the bender so I offered to buy it back. He agreed. Bent up a template for the sissy bar I am building last night. Very happy how it is coming along.
Offline Kelly E
  • Geriatric Hooligan
« Reply #113 on: August 13, 2025, 11:28:29 AM »
Well that was a handy transaction. 8)
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline Dime
« Reply #114 on: August 13, 2025, 11:31:21 AM »
Absolutely. Was just working on the sissy bar for a few minutes. It is bending up nicely. Bit of trial and error but that is to be expected
Offline Dime
« Reply #115 on: August 17, 2025, 04:28:36 AM »
Everything is mocked up for the sissy bar. Just need to v cut the faces and weld. Then I will see if my buddy can do the final welding.
Offline Alan F.
« Reply #116 on: August 17, 2025, 05:51:19 AM »
That'll be a nice Trident, good work.
Offline Dime
« Reply #117 on: August 17, 2025, 06:06:32 AM »
Thank you sir
Offline Dime
« Reply #118 on: August 17, 2025, 04:05:07 PM »
Ready for final welds.
« Reply #119 on: August 17, 2025, 08:31:23 PM »
Shades of 1970!
:o
Online newday777
« Reply #120 on: August 18, 2025, 03:26:26 AM »
I still have this that was bought in the 1970s on my K5 750. I wasn't the original owner of this bike but knew the original owner and worked with him at the Honda shop. I was the parts manager and sold him this forked bar.
I don't always have it on the bike. The fork bar slides in (and out) of a square tube of the rail brackets(the brackets and fork bar were part of the package) and is bolted in place.
I also had one on my own red K6 back in the 70s
Offline Dime
« Reply #121 on: August 22, 2025, 09:17:44 AM »
Shades of 1970!
:o
Exactly what I was going for 8)
Offline Dime
« Reply #122 on: August 22, 2025, 09:18:38 AM »
That is sweet friend. Love an old trident
Offline Dime
« Reply #123 on: August 22, 2025, 09:20:27 AM »
The trident is done. Local shop did the final welds for me.  Not perfect but am happy for my first time making one.
Offline Dime
« Reply #124 on: August 27, 2025, 03:38:18 AM »
One of my Brothers up in BC had a 1980 kz1000 ltd scraped and sent me the front fender along with front calipers, lines and master cylinder.
I am sizing up the front fender but it is kinda hard to tell how it fills out without a tire in place.
I was thinking about chopping it but with the bead rolled into the fender it makes it near impossible to chop it and make it look clean.
