Author Topic: 500/4 Front Brake Master Cylinder - All the same?  (Read 868 times)
Offline Rod
« on: September 30, 2024, 01:55:42 AM »
Could someone tell me if all years of CB500 used the same front m/c? I need an overhaul kit but don't know the year of manufacture of the m/c as it's from a donor bike. Thanks
Offline robvangulik
  • Honda Fourever
Re: 500/4 Front Brake Master Cylinder - All the same?
« Reply #1 on: September 30, 2024, 02:12:06 AM »
Yes, all the same and all 14mm.
« Reply #2 on: September 30, 2024, 02:23:11 AM »
Better to buy the repop master from Dave Silver, not much dearer than a kit and the kits can be a swine to fit and bleed
Offline Little_Phil
« Reply #3 on: September 30, 2024, 03:00:39 AM »
I've just refurbed a couple. Have you taken yours apart yet? The circlip is difficult to remove and I had to modify clip tool. In some cases the circlip is too corroded and breaks and then just about impossible to pull apart. But yes the kits are all basically the same.
To make them look OK I bought some large dia heat shrink for the reservoir and painted the lower half.
« Last Edit: September 30, 2024, 03:02:45 AM by Little_Phil »
Offline Rod
« Reply #4 on: September 30, 2024, 04:12:03 AM »
Thanks Guys, useful info. The circlip does look pretty corroded but will give the tear-down a go, and the David Silver option as plan-b.
« Reply #5 on: September 30, 2024, 08:03:14 AM »
+1...a lot of us dont bother rebuilding the masters anymore...
https://www.davidsilverspares.com/CB500K0-FOUR-1971-USA/part_218499/
« Reply #6 on: October 01, 2024, 06:53:48 AM »
+3 for the DSS repop. Order the better looking cap when ordering. Not much extra. It has a stock look.
Offline Little_Phil
« Reply #7 on: October 01, 2024, 09:54:05 AM »
There are noticeable differences. eg: reservoir on the stock M/C protrudes forwards, the repro comes back over the bars. There is ribbing on the outside. Use your original cap if it's good.
