Author Topic: Front sprocket 1978 cb750k  (Read 707 times)
Offline Dime
« on: October 02, 2024, 07:07:01 AM »
Ok so I got the cover off and the front sprocket looks to be in good shape however I am not sure it is the right sprocket for the bike.
It is 17 tooth like I want but from what I can size up it has play in it due to not having a raised face like JT Steel Front Sprocket 17T (530) - JTF338.17 once the bolt and washer for the sprocket is in place.
I am guessing someone did a slap together job of converting to 530 chain. Which does not surprise me acording to all the other work done on the bike.
Maybe I am overthinking this as well and it is supposed to have play between the washer and sprocket but it doesn't make sense.
Anyone want to let me know if I am over thinking this?
Re: Front sprocket 1978 cb750k
« Reply #1 on: October 02, 2024, 07:11:09 AM »
That is a sprocket for an earlier bike that locates with a fixing plate and two bolts into the threaded holes
Offline Dime
« Reply #2 on: October 02, 2024, 07:28:55 AM »
Ok I am going to have to count the rear sprocket teeth and see what I am into here. It was too much to.hope something was done right on this bike, LOL.
Thank you
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #3 on: October 02, 2024, 08:44:07 AM »
Did you remove the transmission/shift cover to get the sprocket cover off, or had you planned to remove the trans/shift cover anyway? The sprocket cover can be removed without removal of the shifter cover as demonstrated in a short video I did here:
There is a link to the post in my sig below as well as one or more links to 630 to 530 conversion info.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Dime
« Reply #4 on: October 02, 2024, 09:04:13 AM »
I planned on removing it anyway. The stator was suspect. One of the yellow wires turned out to be burned. I cut off all the old ends going to the stator and tested and all the yellow wires tested 0.4 ohms as it should so at least the stator is good. Will be testing the rotor next.
« Reply #5 on: October 02, 2024, 09:46:59 AM »
You mean field coil, the rotor is a lump of steel with a wavy groove in it
Offline Dime
« Reply #6 on: October 02, 2024, 09:48:57 AM »
Field coil is on the list too but no I meant pulling the cover and testing the rotor.
« Reply #7 on: October 02, 2024, 09:50:26 AM »
There is no test you can do on the rotor except is the crank bent
Offline Dime
« Reply #8 on: October 02, 2024, 09:52:34 AM »
Maybe I am not using the right term but I am taking about doing an ohm test which should result in between 4-10 ohm between the rings
« Reply #9 on: October 02, 2024, 11:35:53 AM »
That is for the field coil not the rotor, the generator consists of 3 parts
1 the field coil
2 the stator coils
3 the rotor
A Honda document of the 3 phase charging circuit is attached
Offline Dime
« Reply #10 on: October 02, 2024, 12:17:57 PM »
1 the field coil
2 the stator coils
3 the rotor
Ok cool. Thanks for clearing that up for me. I was obviously confused
« Reply #11 on: October 02, 2024, 01:29:57 PM »
No problem you aint the first and wont be the last, hope the document explains the charging sytem for you
« Reply #12 on: October 02, 2024, 01:40:47 PM »
That test is for a DOHC, which has a different alternator. The SOHC field is the white and green wires that are with the 3 yellow stator wires, and should read about 7 ohms.
Offline Dime
« Reply #13 on: October 02, 2024, 01:53:58 PM »
Maybe I am not using the right . I am taking about doing an ohm test which should result in between 4-10 ohm between the rings
Thank you. I am used to dohc. This is all new to me.
I tested the wires as you said and got exactly 7 ohms.
So looks like the burnt wire at the connector for the yellow wire was the issue
« Reply #14 on: October 02, 2024, 01:56:59 PM »
Both the field and stator are attached to the inside of the alternator cover. The stator goes over the outside of the rotor, which is bolted to the end of the crankshaft, and the field coil goes inside the rotor. The field coil is an electromagnet: when current flows through it, it magnetizes the rotor, which in turn induces current in the stator. The regulator controls how much current flows through the field, which in turn controls the output from the stator.
Offline Dime
« Reply #15 on: October 02, 2024, 02:01:56 PM »
Thank you for taking the time to.break this down for me. Electronics is not my.strong suit. I barely passed electrotec as part of my mechanic program but still managed to graduate top of my class. So ya I definitely struggle in this area and appreciate the time you guys are taking to help sort this out.
« Reply #16 on: October 02, 2024, 08:46:26 PM »
Dime,
I think your looking for a 17 tooth later model genuine Honda 650 sohc single shoulder 530 sprocket that uses the single center retaining bolt… I believe this one spaces the sprocket away from the case like the OEM 630 sprocket did..
The earlier OEM Honda’s to76 (750s) had a shoulder on each side that used the two bolt spline lock retainer..
« Last Edit: October 02, 2024, 08:48:12 PM by Tracksnblades1 »
Offline Dime
« Reply #17 on: October 03, 2024, 12:32:10 AM »
Dime,
Thank you. In another one of my posts a gentleman touched on this very thing about the shoulder on the sprocket and how it needs to.go inward. I had just forgotten
You guys are so helpful. It is much appreciated
