Author Topic: Belfast-2-Belfast-By-Bike: Part 3  (Read 20195 times)
Re: Belfast-2-Belfast-By-Bike: Part 3
« Reply #50 on: January 26, 2025, 11:02:20 AM »
 I can't tell by the sound but my old race motor has stretched primary chains (70mm) and it makes a crazy noise. That doesn't explain the catching at TDC however.
Offline The Lone Builder
  • "Still running against the wind"
    • Belfast-2-Belfast-By-Bike
« Reply #51 on: January 26, 2025, 12:28:36 PM »
Spent quite a bit of time on Sunday morning trying to adjust valves to get rid of that "sticking point". Also checked for oil at the top even though I was sure thee passages were clear and pressure good.
I knew the passages were clear because the oil I poured over valves and cam during assembly ended up on he floor as eat oil hoses were not connected!  :)
No 4 exhaust seemed to be the main culprit in the stickage (?) so I adjusted it. When finally free, the gap was >0,3mm (0,012"). I don't know exactly what it was because I couldn't get a larger feeler gauge in; the 0,3 gauge had plenty of room though.
Reasoning tha this wasn't going to work for long, I started thinking of options and coming up with nothing that sounded reasonable, I called Honduran for some advice. Mark agreed that my head was probably useless - most people wouldn't be surprised about that  :D – and that 2 head gaskets wasn't the way to go.
He just happened to have, to hand, a head that he had already worked on and was ready to fit. SO now that is on its way to me and I am in the process of taking the engine out again.
So when disaster strikes, just remember, "It'll be all right in the end, and if it's not all right, it's not the end!" The Belfast Odyssey continues!  ;D
CB750 K2 - From Belfast-2-Belfast
CB750 K1 - The less, said the better!
CB450 K1 - Stalled.
CB400F Supersport - Not Rusty any more!
Follow my journey through Africa @ http://Belfast2BelfastByBike.com
« Reply #52 on: January 26, 2025, 12:47:44 PM »
Fantastic that you can repair on your tour very far away from home. ;)
A real adventure.
I'm curious about that head's height.
How much that was shaved off.
It is very easy to get the cam chain a tooth wrong too.
Important to rotate engine a few turns without plugs after assembly  to double check the markings, crank vs  cam when tensioner is mounted. I learned that the hard way 40 years ago.
No damage, only ticking sound at start-up. Engine went out direct....
Offline jaytee-nz
« Reply #53 on: January 26, 2025, 12:49:32 PM »
Sean, I'm 400 km's away from you but if I can help in any way please let me know.
Unfortunately, I don't know anyone in Auckland who could assist you (it's a city I try to avoid!).
Cheers - John (JT)
« Reply #54 on: January 26, 2025, 11:06:37 PM »
Well  took the engine out and removed the rocker cover.
As PeWe suspected, the cam chain was one tooth off. I have corrected that and set the clearances as per the manual. The engine turns over smoothly now.
Question is whether the previous interference has bent the valves. If I take the head off and remove the valves, would I be able to see if they were bent?
Would checking the compression give the same answer?
CB450 K1 - Stalled.
« Reply #55 on: January 26, 2025, 11:17:31 PM »
Cheers - John (JT)
Thanks John.
My plan, once back on the road is to head south down the east side, over the South Island and then when coming back go up the west side of North Island.
I'll give you a shout as I approach New Plymouth; or sooner if I need more help!  :)
CB450 K1 - Stalled.
Offline jaytee-nz
« Reply #56 on: January 26, 2025, 11:18:25 PM »
Low compression might indicate a bent valve but the only way to know for certain is to remove the valve. If you have the use of a drill, put the valve in it and see if it spins without a wobble.
Sounds like a plan, so give me a shout when you are coming my way.
« Last Edit: January 26, 2025, 11:20:32 PM by jaytee-nz »
« Reply #57 on: January 26, 2025, 11:33:28 PM »
That sounds like a plan. Tomorrow I can get a compression tester. If all cylinders are equal and reasonable, I'd say good to go.
If one is much less than the others, then I'd have to take that one out and check it.
I know this is a rough approach, but what else?
CB450 K1 - Stalled.
« Reply #58 on: January 27, 2025, 11:00:13 AM »
A compression check is one way: another (if the head is off) is to turn the head upside down and pour some gas into each chamber to see how long before it runs out - and which way.
« Reply #59 on: January 27, 2025, 11:53:18 AM »
I have heard valve to piston due to chain a tooth off. No problems seen afterwards except small dents in pistons. A light clicking sound.
If you have a compression tester and all are rather equal.
My K2 with stock Cruzing image pistons had 150-160 PSI.  Valves vs seats were recently refurbished.
Cheap compression tester, throttles wide open.
Run on starter, ign off.
All plugs off will help.
Make sure that there are no sand or pebbles on head that can fall inside.
« Last Edit: January 27, 2025, 11:56:47 AM by PeWe »
« Reply #60 on: January 27, 2025, 01:15:22 PM »
The engine is still on the bench, but the head is not off. I was thinking to is just to see if all were similar. If so I'd just put it back together. If not, then I'd have to  go further.
A real adventure.
It is fantastic Per, but only possible because of the generosity and hospitality of people who welcome me along the way and the great support and advice I receive from members of this forum.
CB450 K1 - Stalled.
« Reply #61 on: January 27, 2025, 07:01:54 PM »
Do you have another head gasket?
And, can you get some Parker O-rings there, part #02-111 ? These are the 2.6x10.8 O-rings needed in those 2 oil ports in the head gasket so it won't leak.
PM me if you decide you need two, I could send those airmail?
« Reply #62 on: January 27, 2025, 08:40:34 PM »
I've made progress!
I removed the head again. On inspection there were marks on both pistons and exhaust valves. I put some petrol into the combustion chambers and after 8-10 minutes, there were no leaks whatsoever, either down the exhaust, or the inlet ports.
So happy days, I seem to have got away with it. :)
I do have another head gasket Mark, thanks, and the o-rings - 2.65 x 10.8. I brought them with me!
So the head is back on and now I'm just waiting overnight so I can re-torque it. Then, with any, unusual, luck, I'll be on the road by Thursday. 🤞
CB450 K1 - Stalled.
« Reply #63 on: January 28, 2025, 01:20:39 AM »
I've made progress!
Yahoo! 👍
« Reply #64 on: January 28, 2025, 06:44:11 AM »
Good to hear!
« Reply #65 on: January 28, 2025, 07:15:15 AM »
Hope it works out
« Reply #66 on: January 29, 2025, 11:53:19 PM »
Uo and running!
https://youtube.com/shorts/dWPQMX5qchE?feature=share
Had a ride of +/- 20Km. Seems to be a bit uneven, but got me home.
Tomorrow a bit of a tune up.
CB450 K1 - Stalled.
Offline jaytee-nz
« Reply #67 on: January 30, 2025, 12:06:38 AM »
Great stuff Sean. Sounds like a normal cold CB750 engine to me !
« Reply #68 on: January 30, 2025, 07:25:16 AM »
Nice sound!
I prefer a little bit higher idle to improve start when cold and when riding.
Not that abrupt deceleration at throttle off in low speed and easier take offs.
Minimum 1200 rpm when really warm. 1400rpm is ok too ;D
« Reply #69 on: January 30, 2025, 11:05:05 AM »
Old Hondas never really die. Some are just allowed to rust away.
Offline b1jackson
« Reply #70 on: February 03, 2025, 04:02:04 PM »
That’s where the Old Honda Rescue Centre comes in!
ohrc_vintagemoto on Instagram
« Reply #71 on: February 04, 2025, 01:52:53 AM »
 Ready for adventure.
Offline rotortiller
« Reply #72 on: February 04, 2025, 07:09:02 AM »
This is a little late but if you do not have a compression gauge and suspect a bent valve you can remove the carbs and hold your palm over the intake boot for a firm seal and feel the suction while slowly turning turning over with the kick starter. It is surprising how long the suction holds at the end of the intake stroke. A bent leaking valve will not allow that.
« Last Edit: February 04, 2025, 07:15:59 AM by rotortiller »
« Reply #73 on: February 04, 2025, 05:33:07 PM »
Uo and running!
Well done and all the best for the coming travels! Maya says “ ride safe!”.
« Reply #74 on: February 05, 2025, 01:42:41 PM »
It never stops! Or rather it keeps stopping!
I've had an intermittent misfiring issue for the last 3 days.  :(
Started on Sunday and then cleared. No 4 plug was black and wet, so I changed this.
Monday was great, ran sweetly.
Tuesday a rest day
Wednesday it started out OK, but then the misfire returned.  Same story with the plugs - 1-3 looked OK but. 4 was sooted. I changed all 4 plugs this time, and the bike died completely. I noticed the tank was almost empty - after only 130 Kms! – and switched to reserve. It ran OK around the carpark, but as soon as I loaded up and set off, the misfire returned.
This morning, Thursday, I took out the plugs: 3 & 4 were black while 1 & 2 were clean. The second pic shows the old plugs with the new ones.
Anyone have any thoughts?
I'm going to check coils, plug caps and plugs now, but it is unlikely that both coils are failing. Failing plug caps, again? Two HT leads not  performing well?
CB450 K1 - Stalled.
