Author Topic: Head Gasket kit  (Read 1128 times)
Offline Jenya79
Head Gasket kit
« on: October 05, 2024, 10:26:41 AM »
Hi all,
I am looking to replace my head gasket finally and I was hoping to get a recommendation on a kit (all the seals, coins, etc) and if I could get a rec for the specific gasket. Have any of you gone MLS? Is there a composite head gasket that will not wick oil out of the seal the way the old ones do?
1976 CB750K
« Last Edit: October 05, 2024, 10:42:41 AM by Jenya79 »
Offline Pbeattie89
Re: Head Gasket kit
« Reply #1 on: October 05, 2024, 10:35:31 AM »
Assuming you are talking about a sohc 750. The kits from Ken at cyclex are really nice. They come with everything you need. With the MLS head gaskets, HD head studs are recommended. Surface finish on the head and cylinders are also vary important for MLS gaskets to work properly.
Sent from my SM-G991W using Tapatalk
Re: Head Gasket kit
« Reply #2 on: October 05, 2024, 10:36:53 AM »
Welcome aboard the forum Jenya79
You will need to tell us what bike you are working on and needing the gaskets for
Offline Jenya79
Re: Head Gasket kit
« Reply #3 on: October 05, 2024, 10:41:37 AM »
Thank you for the quick reply. For the surface finishing, is careful sanding sufficient? Do you recommend any other material than MLS?
Offline Jenya79
Re: Head Gasket kit
« Reply #4 on: October 05, 2024, 10:43:30 AM »
76 750, just edited my initial post
Offline Pbeattie89
Re: Head Gasket kit
« Reply #5 on: October 05, 2024, 11:34:47 AM »
If you have a proper surface plate you could lap the surfaces but it would be easier and likely much cheaper to have it surfaced at a machine shop if you don't already have the tools. Standard composit head gaskets work well for standard rebuilds and they are more forgiving for surface finish.
Re: Head Gasket kit
« Reply #6 on: October 05, 2024, 09:15:19 PM »
Take your cylinders to a machine shop and have them milled off (decked) 0.010". If you don't, they WILL leak oil at the 2 oil ports where they pass the oil up to the cam. The modern head gaskets are ALL thicker than the OEM gasket, which was 0.8mm thick (all of the new ones are 1.0mm or even thicker, measure the one you get to find out), so the 2 O-rings in the oil ports cannot seal the ports, and you will have an oily mess after reassembly and less than 100 miles. Bet on it. ;)
Then, PM me for 2 O-rings I will send you to help seal those ports.
Offline Oddjob
Re: Head Gasket kit
« Reply #7 on: October 06, 2024, 05:14:59 AM »
No one tried to make a copper head gasket, ala Alan Millyard and his 6 cylinder Z1? If the thickness is correct then the original orings should be ok as well.
Re: Head Gasket kit
« Reply #8 on: October 06, 2024, 07:48:48 AM »
Alan is a special case, he seems to be able to do anything.
Offline Oddjob
Re: Head Gasket kit
« Reply #9 on: October 06, 2024, 08:07:17 AM »
I’ve got all the tools needed to make one, might give it a go on my 500
Offline The Lone Builder
  • "Still running against the wind"
    • Belfast-2-Belfast-By-Bike
Re: Head Gasket kit
« Reply #10 on: October 06, 2024, 10:00:42 AM »
Mark,
Are those o-rings the 11x2,5 (or 16mm rubber packing) shown on the parts fiche? What size are the ones you have substituted?
If not, which ones are you referring to?
CB750 K2 - From Belfast-2-Belfast
CB750 K1 - The less, said the better!
CB450 K1 - Stalled.
CB400F Supersport - Not Rusty any more!
Follow my journey through Africa @ http://Belfast2BelfastByBike.com
Re: Head Gasket kit
« Reply #11 on: October 06, 2024, 12:45:52 PM »
Mark,
Yep. I bought about 300 (twice) of the 10.8x2.62mm size (Parker #02-111) so I could get them for 5 cents apiece, several years ago. I send them out to anyone who will wait long enough to get them, so they don't end up with a leaking head gasket. They work perfectly with the Vesrah head gasket and the NE type (if you actually get an NE gasket with cylinder holes that match your engine - many don't).
