Author Topic: K4 750 First Start Oil Not Returning to Tank  (Read 3212 times)
Offline pickleknuckles
« on: October 12, 2024, 11:54:29 AM »
I think I know the answer to this one but I need confirmation and the rest of the internet has been no help.
Just finished cleaning up my '74 CB750 after 20yrs in storage. New everything but old pump, fresh oil. Starts fine. Fired the starter till the oil light went out. Then ran it for a bit on a hanging tank just to make sure it was good to go before vacuum sync. Runs really well just idling. Impatience got the best of me and I fired it till the oil light went out again just to hear it crank. Now no oil in the tank... I think that's normal. Do I just need to actually run it so the oil returns? I assume so seeing as there's no other way for it to pump back in. Any thoughts on how long?
Thanks.
Offline 69cb750
Re: K4 750 First Start Oil Not Returning to Tank
« Reply #1 on: October 12, 2024, 12:43:36 PM »
Oil tank level will decrease first time bike is started.
Peer into tank, if there is oil in tank bottom add more.
If tank is dry you have a problem.
« Reply #2 on: October 12, 2024, 01:04:50 PM »
If you had the usual 3.5 quarts of oil to start with a dry engine, it will 'lose' almost a quart in the startup, just below the dipstick. This stays in the engine and oil filter. Add about 1/2-3/4 quart more before running it again, though. Reason: if the oil pump went dry, chances are the 50-year-old oil seal between the 2 chambers is both hard enough and has enough wear clearance that it cannot get a vacuum on the suction side to send oil back to the tank. This will pump the tank fully dry and wreck the crankshaft and bearings. I have a black-painted K4 engine in the garage now that someone got impatient with and just started it up anyway - it needs a crank and all new bearings! :(
« Last Edit: October 17, 2024, 07:45:46 PM by HondaMan »
« Reply #3 on: October 12, 2024, 01:14:37 PM »
If you mean the oil dissapeared overnight it has leaked through the pump into the engine which about 75% of the 750's do
« Reply #4 on: October 12, 2024, 06:59:18 PM »
No, leaking back. I cranked it just to hear it and watch the oil light go out. It's been 20 years. Lol.
If you had the usual 3.5 quarts of oil to start with a dry engine, it will 'lose almost a quart in the startup, just below the dipstick. This stays in the engine and oil filter. Add about 1/2-3/4 quart more before running it again, though. Reason: if the oil pump went dry, chances are the 50-year-old oil seal between the 2 chambers is both hard enough and has enough wear clearance that it cannot get a vacuum on the suction side to send oil back to the tank. This will pump the tank fully dry and wreck the crankshaft and bearings. I have a black-painted K4 engine in the garage now that someone got impatient with and just started it up anyway - it needs a crank and all new bearings! :(
There's definitely oil in the tank below the stick. I can see the rear tube on the underside flush w the oil level.
https://photos.app.goo.gl/6dcRT9GXMiuHKabP9
« Last Edit: October 12, 2024, 07:02:27 PM by pickleknuckles »
Offline rotortiller
« Reply #5 on: October 13, 2024, 03:51:59 AM »
That picture looks like the oil level is flush with the pickup in the oil tank, not good as it will eventually suck air as hondaman said. I would expect the oil pressure light to come on when it does cavitate. If the system already took 3 liters of oil and the tank is basically empty you have a problem. I would not run the engine until the tank oil is at least several inches above the tank bottom(showing low on dip stick) and then keep an eye on it .
« Reply #6 on: October 13, 2024, 04:03:40 AM »
Cool. That's what I was trying to figure out. So it's lower than the filled-from-dry scenario Hondaman suggested?
I need to put a new pan gasket on anyway, so I'll just rebuild a pump and toss it in while I'm at it. I bought this bike in the early/mid '90s and it's been sitting since November of 2001, so I'm not surprised.
« Reply #7 on: October 13, 2024, 06:01:13 AM »
Good idea, look at that pump. Either the pickup screen is varnished over with gunk or time for some pump work…..
Offline rotortiller
« Reply #8 on: October 13, 2024, 06:59:07 AM »
Basically if you put 3 liters in the oil tank during the oil change the oil level in the tank should be higher than in the picture.
« Reply #9 on: October 14, 2024, 08:21:11 AM »
Thanks! That's the input I was looking for.
Online Don R
« Reply #10 on: October 17, 2024, 08:42:57 AM »
 Let us know what you find, if anything. You aren't the only guy that runs into this issue.
« Reply #11 on: October 24, 2024, 10:48:51 PM »
Will do! I've got a couple good pumps here and I ordered a rebuild kit w cometic gaskets, a new screen and rubber parts, and new springs from CycleX. Also shot a coat of paint on a pan I had vapor blasted a while back.
Just dropped the bike off to have the frame checked and straightened though so it might be a few weeks till I get it swapped out.
« Reply #12 on: October 28, 2024, 06:21:28 PM »
Your forum name reminds me of a fella I met once in Missouri at one of their public shooting ranges. He'd ordered a Rowland conversion kit for his old Army .45 and had a 'smith build it up, took it shooting at the same range where I was, next lane over. For some reason he decided to remove the slide and on reassembly, the VERY strong recoil spring was fighting back, big time. He asked he to help him out by holding the frame while he installed the spring, saying his 'pickleknuckles of fingers' had trouble with small parts like the bushing. His fingers were BIG (like him, a good 300 lbs, 6'6" at least) and thick, bigger than my thumbs!
« Reply #13 on: February 16, 2025, 01:56:06 PM »
Ha! I'm from Missouri and I do have a pretty sweet. 45, but it's a .45-70 breach-loader. And I'm only about 190lb.
« Last Edit: February 16, 2025, 02:10:41 PM by pickleknuckles »
« Reply #14 on: February 16, 2025, 02:06:13 PM »
Thread update: Finally got the bike back. The frame is probably straighter than it was new in '74. Picked up one of the complete rebuilt super whammy pumps from CycleX and a Cometic gasket. Decided to prime it w the vaseline method and got it all installed. Pan is only on loose because I'm waiting on new Honda bolts from CMS.
« Last Edit: February 16, 2025, 02:08:11 PM by pickleknuckles »
« Reply #15 on: February 16, 2025, 03:54:56 PM »
That wouldn't be too hard to come by! Honda actually swapped me a brand-new 750K2 (the one I have now) in 1972 when they discovered my 750K1 frame was so misassembled that the wheels were about 1" out-of-true with each other.
« Reply #16 on: February 16, 2025, 06:31:32 PM »
What is the chassis verification for…?
Have I missed something required in St Louis…?
« Reply #17 on: February 16, 2025, 08:52:59 PM »
Yeah Man !  :) 8) 8)
The Velocity Calibrations suspension/frame place seems top-notch.
Do they only have that one place in the USA ?
« Last Edit: February 16, 2025, 08:58:30 PM by grcamna2 »
« Reply #18 on: February 17, 2025, 06:44:33 AM »
Nah. I hit a car on it at about 45mph back in 2001. Lady made a U turn out of a parking spot on a busy five lane. The bike sat in the back of a garage till 2021 when I needed a covid lockdown project and brought it home. The fork folded so I figured the frame was tweaked and VC happened to be local so I brought it over.
Sent from my Pixel 8 Pro using Tapatalk
« Reply #19 on: February 17, 2025, 06:46:27 AM »
Yeah Man !  :) 8) 8)
They definitely are. Great shop run by a good dude. It was money well spent. I do believe that is their only location.
