Author Topic: Biting off more than I can chew (1977 cb750)  (Read 4704 times)
Offline Floshenbarnical
  • Money pit enjoyer
« on: October 21, 2024, 01:34:27 PM »
Finally time to un-screw the cobbled-together mess of a wiring harness the previous owner put in.
It’s a horrible tangle of harbor freight crimp connections. I have many spools of wire, and many vintage connectors. I have many wiring diagrams for this bike, but because the only stock electronic unit left is the headlight, and the other lights are LEDs, most of the wiring harnesses aren’t super helpful.
The coils/ points/ ignition system is all good to go thanks to Hondaman. Sadly the rest of it needs to get done now.
I did a bad job when I disassembled the harness so about 75% of it is flagged etc, and the rest is going to be trial and error.
If I post exhaustive pictures of my equipment, etc, would any of you be willing to help me figure out the correct way to do this? I’m a little lost.i need to wire up a headlight, 4 turn signals total, and a brake light and a stop light.
'77 CB750 SS
Offline calj737
  • I refuse...
Re: Biting off more than I can chew (1977 cb750)
« Reply #1 on: October 21, 2024, 06:04:17 PM »
See if this helps, it’s as simple a diagram as there is.
  • Money pit enjoyer
« Reply #2 on: November 12, 2024, 09:13:16 AM »
Thanks for this. I downloaded it ages ago but my pc broke down and I lost it. The only thing that complicates things are 1) I don’t have a starter 2) I am using Hondamans ignition. I’m sure I’ll figure it out though.
'77 CB750 SS
Offline calj737
  • I refuse...
« Reply #3 on: November 12, 2024, 01:19:28 PM »
Skip the starter circuit wiring then (the heavy gauge RED from battery to starter motor). I don’t know Marks ignition, but I suspect outside of the stock wiring, it maybe needs a 12v supply to power it? If so, tap the BLK/WHT from the coils as that power comes from the RH control KILL/RUN switchusually.
  • Money pit enjoyer
« Reply #4 on: November 13, 2024, 05:14:28 AM »
I’ll bear that in mind when I take care of that.
Another issue: all the reg/rec diagrams have 5 wires. Mine has 7. It’s one of Rick’s. Not sure where the extra wires go!
'77 CB750 SS
« Reply #5 on: November 13, 2024, 06:41:25 AM »
Originally the regulator and rectifier were two devices. Your single unit has more as it does both jobs. It should have that many…..
Offline calj737
  • I refuse...
« Reply #6 on: November 13, 2024, 01:01:40 PM »
There are 2 separate GREEN wires and each needs its own ground. One is for the Rectifier, the other for the Regulator. The 3 yellows are for the Stator, the WHITE is for the field coil, the RED (or BLACK) is for 12v reference from the battery (don’t connect that directly to the battery, use a switched circuit else the field coil is constantly powered and your battery will drain).
  • Money pit enjoyer
« Reply #7 on: November 14, 2024, 04:06:32 AM »
You mean a switched circuit like a key switch?
Thanks for the help everyone. I have the charging system mocked up and ready to be pretty. Stupid accessories are still kind of a basket case. Not sure whether or not to hook up the power and start plugging the last few connections randomly until something happens, or whether to start from scratch. Depends how hard it is to figure out I suppose.
'77 CB750 SS
Offline calj737
  • I refuse...
« Reply #8 on: November 14, 2024, 05:29:00 AM »
Yes, switched by the key.
  • Money pit enjoyer
« Reply #9 on: November 14, 2024, 02:58:35 PM »
Like this?
Ricks haven’t made my reg-rec in 10 years so the man on the phone drew a diagram:
'77 CB750 SS
Offline calj737
  • I refuse...
« Reply #10 on: November 14, 2024, 06:36:32 PM »
Perfect.
« Reply #11 on: November 14, 2024, 07:19:10 PM »
Like this?
That Reg-Rec's Blue wire should be able to attach then to any Black wire available. The OEM regulator had one terminal for Black, one for Green Ground, and the last one was for the field coil.
  • Money pit enjoyer
« Reply #12 on: November 16, 2024, 12:17:58 AM »
Is the circled item just a connector?
'77 CB750 SS
Online newday777
« Reply #13 on: November 16, 2024, 01:42:29 AM »
No.
It's a starter solenoid
Click on the picture and enlarge to see the words, starter solenoid
  • Money pit enjoyer
« Reply #14 on: November 18, 2024, 12:07:07 PM »
Going ti try to start the bike tomorrow. Quick question though: I have hondaman’s ignition but I’m suddenly paranoid I wired the points back to front. They’re inside heat shrink so I can’t see. What will happen if I start it and they’re connected wrong?
'77 CB750 SS
Offline calj737
  • I refuse...
« Reply #15 on: November 18, 2024, 12:30:15 PM »
It won’t start as the firing order is backwards. Easy enough to reverse afterwards.
  • Money pit enjoyer
« Reply #16 on: November 19, 2024, 10:00:06 PM »
Ok. As long as it’s not going to fry anything. I left the connections open to make it easier to switch before protecting them with heat-shrink tubing.
Another thing that occurs to me: my current turn signal for my rear system has a wire for the left and a wire for the right indicator. That’s fine for the indicators in my bars, but my rear unit is a single piece that incorporates both left and right turn signals and only has a single + wire and a ground wire. How do I figure this out?
'77 CB750 SS
« Reply #17 on: November 20, 2024, 05:11:04 AM »
Left and right turn signals are definitely fed by two different (+) wires. Front and back.
Offline calj737
  • I refuse...
« Reply #18 on: November 20, 2024, 06:12:24 AM »
Unless you install a diode for the rear turn signal isolating the R+ from the L+. So that may be your requirement, but I’d really want to see the fixture and any wiring instructions that came with it.
  • Money pit enjoyer
« Reply #19 on: November 20, 2024, 01:00:12 PM »
Of course. Here is a picture of the unit. Red is running light. Black is ground. Blue is brake light. Yellow is turn signal.
'77 CB750 SS
« Reply #20 on: November 20, 2024, 02:34:28 PM »
Your Transistor Ignition has a Lifetime Warranty, too! Just let me know if it breaks, I'll swap you for another one.
Offline calj737
  • I refuse...
« Reply #21 on: November 20, 2024, 04:16:55 PM »
Usually, the TAIL and BRAKE are integrated in units like those, leaving the Blue and Yellow for indicator lights.
Do a test, temporarily wire the Tail and Brake together, turn the key ON to confirm you have Tail. Then squeeze the Brake and see if the intensity doesn’t change. If so, there’s your answer. Wire the Blue to Left turn and Yellow to Right.
  • Money pit enjoyer
« Reply #22 on: November 20, 2024, 07:10:27 PM »
Well, you guys are all brilliant and I’m a fool - this is a unit of TWO that are supposed to be installed side by side
I performed a simple test by simply touching leads to the battery. Black is ground, red is TAIL, blue is HIGH and yellow is turn. Yellow only lights up one side of the LED strip, and I expected it to light turn signals on each side.
I recalled that I had received two when I ordered it, and found it in my box O supplies. I then recalled that I had been like “oh, bonus! They sent me a dupe!” whereas in actual fact I couldn’t read the website properly.
Luckily I haven’t drilled the slit for it yet so I’ll just install both! They each get their own TURN lead for left and for right! It affects the aesthetics a little but a blessing is that it’ll be twice as bright. And good grief they’re bright already for such little lights.
'77 CB750 SS
  • Money pit enjoyer
« Reply #23 on: November 20, 2024, 11:32:02 PM »
Honestly having looked at some wiring diagrams, the instructions for the equipment, and learning some basic principles about electrical systems, I’m pretty confident I can throw out all his work and do it much better and simpler myself. I think the reason it’s such a complicated mess is because he has tried to force the stock wiring design onto the equipment he purchased instead of slightly modifying the equipment and imagining a new diagram. I’m specifically talking about the lighting, inc. dash lights.
Edit: figured it out. Accidentally stayed up until 2am drawing the entire diagram for my bike and all its equipment. Then I tested all the lighting circuits in an online tester and it all works! Time to get soldering!
« Last Edit: November 21, 2024, 05:08:24 AM by Floshenbarnical »
'77 CB750 SS
Offline calj737
  • I refuse...
« Reply #24 on: November 21, 2024, 05:22:21 AM »
I think you mean BLUE is BRAKE, not HIGH. The tail light should change its intensity with the brake lever being actuated.
