Author Topic: Another Clutch Adjuster Removal Question  (Read 3895 times)
Offline calj737
  • I refuse...
Re: Another Clutch Adjuster Removal Question
« Reply #25 on: October 29, 2024, 03:53:53 AM »
Bit premature Calj, you have no idea what I was about to suggest. It's about what you put in the end of a Dremel not the Dremel itself. I have tools that go down to 2000 grit, that's lighter than a pumice stone on your skin. It's not the grit, it's the pressure that matters. Plus these tools can get into gaps you cannot get pads into, like this piece done entirely (well 99%) with these tools.
Different task for a different tool, Oddjob. Regardless of how much pressure you apply with a spinning tool, the amount of surface material you remove is not nearly as controllable as doing so by hand. For a carb body, sure, have at it with a Dremel; it’s a very good choice. To clearance a hole whose diameter is significantly larger than the bit, I’d rely on hand technique with a fine grit pad. A few rotations on each part and you’re likely to have all the clearance you need. As I said, you need only remove thousandths to have proper movement.
