I have no F2 cam. Only the earlier K7/K8/F1 cam. Not higher lift than my old K6 cam.
Cruzin image pistons are good. Need tight clearance.
Their 836 not for higher lift cams. There is a long thread about those pistons in the SOHC Bikes forum.
My CB750 K2 has a Cruzin image set, +0.50mm, 392 type with a little higher domes than stock K.
It has the same type of cam as I showed.
A good head and not worn stock cam  will make it a fun bike.
An old head can be OK too
My K2 has 4-4, Yamiya No numbers (like HM300) and runs fine. Head  restored with new guides, valves and springs.
58 WHP on dyno a few years ago. It runs better now after carbs replacement.
From K6 carbs (086A) to better jetted CB750F-75 (064A) carbs, so maybe 60WHP. 17:48 sprockets and stock 4.0-18 tire make it to run fine.
My K6 with 970cc and +100WHP back to 17:48 sprockets. I tested 18:48 again during  a week or 2.
It felt not as fun anymore when I often need to pass slow going cars. I had to gear down when doing a caravan of cars....
Throttle response felt boring so the 17t front went back in. Rear tire wider 130/80-18, close to stock diameter.
